Pat's Ebay Turbo Compound Boost Build
Old 03-18-2017, 07:32 AM
  #1141
3rdCarMX5's Avatar
I am enjoying following along, so happy you didn't put it in the wall.
3rdCarMX5 is offline
Old 03-18-2017, 08:01 AM
  #1142
miata2fast's Avatar
Total Cats: 174
Wow. That is hauling ***. You are in the 10's with that mph. You get the car to hook and your 1/8th will be easy 6.80s.
miata2fast is offline
Old 03-18-2017, 08:17 AM
  #1143
oreo's Avatar
Total Cats: 95
Man, that is quick!
Pat - what do you estimate your Torque/HP numbers are, at 31psi?
oreo is offline
Old 03-18-2017, 08:57 AM
  #1144
Total Cats: 3,075
V8R tubular rear arms and something harder for bushings or bearings.
sixshooter is offline
Old 03-18-2017, 12:57 PM
  #1145
Total Cats: 558
Congrats!
Can't wait to see the 1/4 mile results.
Good save on whatever broke.
I like how your shabby 60' times are my good ones I know, I know, tires.
sonofthehill is offline
Old 03-18-2017, 05:53 PM
  #1146
patsmx5's Avatar
Total Cats: 519
Originally Posted by oreo
Man, that is quick!
Probably a solid 400whp/330 torque. I ran a 500whp Bmw 3 series N54 and beat it by over 1/2 a second and 4mph. I've run the car with more power than this before on the street, but not at the track. It honestly scared the crap out of me when I hit 2nd, after that I parked and didn't run the car again. Hopefully will look at it tonight and see if I can find anything obviously broken or damaged.
patsmx5 is offline
Old 03-18-2017, 06:46 PM
  #1147
Total Cats: 104
WTF. I'm waiting to hear the hate on you in this thread, but your mph in the 1/8th is faster than a lot of miatas do in the 1/4.
Leafy is offline
Old 03-18-2017, 08:40 PM
  #1148
patsmx5's Avatar
Total Cats: 519
I just inspected the underside of the car. Cracked bushings on passenger side wheel are visible. Didn't see any cracks in the subframe though, and I looked it over pretty well. I think I'm going to do poly bushings and beef up these control arms for now. The V8R control arms looks nice, but sweet jesus they are pricey! I'm not sure of the condition of wheel bearings or ball joints. If those are cheap I will replace those as well, or if they are damaged. Not sure those can be inspected without disassembly though. If cheap I'll just buy them and change while it's all apart. I have read all kinds of post about every hub/bearings sucking, so no idea what to buy in that regard. Mine are stock mazda parts right now.
patsmx5 is offline
Old 03-18-2017, 10:03 PM
  #1149
Total Cats: 104
Dude, just buy the V8R arms with sphericals. You're a drag racer, you know how way ******* better stick axle cars hook up with spherical links, same'll go for double a arm.
Leafy is offline
Old 03-19-2017, 12:43 AM
  #1150
dude that thing is hauling. thats low 11's at high 120's per the calculators. congrats!!
definitely a 10 second car once dialed in and fixed
Old 03-19-2017, 12:54 AM
  #1151
Total Cats: 1,184
Wheel bearings and ball joints are easily inspected as part of a basic inspection. Grab the wheel top/bottom then side/side and rock it. Any play is either bushing (unlikely on miatas) or ball joints. If it's both, you either have multiple issues or it's wheel bearings.
curly is offline
Old 03-19-2017, 02:02 AM
  #1152
patsmx5's Avatar
Total Cats: 519
Thanks! Yeah it was pulling hard once the turbos were hitting full boost. I think I can get it well into the 10's with this turbo setup when it's turned up all the way, I got at least another 130-150whp worth of fuel system left before I'm out of fuel again.
I will do that and see what I find, thanks for the tip!
patsmx5 is offline
Old 03-19-2017, 07:55 PM
  #1153
patsmx5's Avatar
Total Cats: 519
I did this test on the rear wheels. Drivers side is loose, obviously has a bad wheel bearing as it makes a metallic clunking sound shaking it left/right or up/down with minimal force. Passengers side seems ok shaking it with light force, but it might have a touch of play in the wheel bearing.
But if I actually pull/push hard on each wheel left/right, I can move them a total range of 2-3 degrees with my hands. With my knees, I can bend the wheels back and forth a total range of probably 5 degrees if not more. Scary they move that much with just me pushing on them. It's obvious that the bushings flex a bunch on both sides, and the wheel bearing on drivers side is very worn.
I spent a few hours reading all about bushings. It seems Sean has a good setup, but doesn't have a source for his bronze bearing/bushings at the moment and no ETA on when that will happen. And poly bushings will be stiff, but stick bad because poly on steel is not a good bearing.
What should I do? Run poly bushing and buy the bronze bearings once available? Also, what wheel bearings should I buy? I just daily drive it and drag race, I don't do 30 minute laps.
patsmx5 is offline
Old 03-19-2017, 08:02 PM
  #1154
Monk's Avatar
Total Cats: 616
Wink
I'm pretty sure the tapered roller bearings are available now.
There isn't a lot of feedback about them yet, but theoretically, they should be very stout.
I know how much you like theoreticals.
Monk is offline
Old 03-19-2017, 08:39 PM
  #1155
What you should replace your bushings with
Old 03-19-2017, 08:42 PM
  #1156
patsmx5's Avatar
Total Cats: 519
I'm going to keep telling you that I'm never doing that. But I will let you know when I decide to swap a Ford 9" rear end into the car.
patsmx5 is offline
Old 03-19-2017, 08:52 PM
  #1157
I'll keep that post around for the I told you so quote.
Old 03-19-2017, 09:26 PM
  #1158
afm
afm's Avatar
Total Cats: 508
McMaster sells SAE 863 sleeve bearings in loooots of sizes.
afm is offline
Old 03-19-2017, 09:50 PM
  #1159
patsmx5's Avatar
Total Cats: 519
afm, I will look into that. I'm guessing that would take a while at best to spec every bearing for the bushings.
What are everyone's thoughts on the IL motorsports, 40% stiffer-than-stock rubber bushings? Or the mazda motorsports 40% stiffer bushings? These vs poly, would poly or delrin be noticeably stiffer? It seems these options don't bind, and don't squeak, and I can just buy and install.
patsmx5 is offline
Old 03-19-2017, 09:53 PM
  #1160
Fwiw we will sell poly bronze setups still. Just not at the same price.
I think delrin might be the way to go for you. It's stiffer than poly, won't squeek or anything.
Quick Reply: Pat's Ebay Turbo Compound Boost Build
