#8821
Total Cats: 558
![](https://www.miataturbo.net/images/smilies/bowrofl.gif)
So a single plate with the hole size of your choice, some paint removal and some zapping.
What you want is a bulkhead tank fitting with a flange larger than that hole. I might have an appropriate fitting somewhere in my garage, I will have a look after work, but they are called bulkhead tank fittings.
#8825
Had a nice scare today with the bearings. ACL has been backordered since January. Managed to find a set on ebay, and a set on amazon. So I ordered both. We will see who gets here first.
Spent some time on the lathe today and made some lower delrin bushings. Might help a bit more with the wheel hop. Burnt off my old ones too.
![Name: XDgrcZW.jpg
Size: 3.19 MB](https://www.miataturbo.net/attachments/build-threads-57/235855d1683054438-aidans-loose-oily-bunghole-actually-runs-track-lap-xdgrczw.jpg)
![Name: kjQd02B.jpg
Size: 1.43 MB](https://www.miataturbo.net/attachments/build-threads-57/235856d1683054438-aidans-loose-oily-bunghole-actually-runs-track-lap-kjqd02b.jpg)
![Name: j1abT7W.jpg
Size: 1.66 MB](https://www.miataturbo.net/attachments/build-threads-57/235857d1683054438-aidans-loose-oily-bunghole-actually-runs-track-lap-j1abt7w.jpg)
![Name: 2uSvDLp.jpg
Size: 1.29 MB](https://www.miataturbo.net/attachments/build-threads-57/235858d1683054438-aidans-loose-oily-bunghole-actually-runs-track-lap-2usvdlp.jpg)
![Name: XDgrcZW.jpg
![Name: kjQd02B.jpg
![Name: j1abT7W.jpg
![Name: 2uSvDLp.jpg
![Name: zpyThgK.jpg
Size: 1.12 MB](https://www.miataturbo.net/attachments/build-threads-57/235859d1683054438-aidans-loose-oily-bunghole-actually-runs-track-lap-zpythgk.jpg)
#8829
broken cutting tool, trashed bushing. The usual ![big grin](https://www.miataturbo.net/images/smilies/biggrin.gif)
I came up with a much better system the next time around. The bushings don't actually have to have to be perfectly centered. As in the outside isn't constrained by anything. So I just tossed shorter pieces in the 3 jaw and went to town.
#8830
SadFab CEO
Total Cats: 1,142
I showed the picture of you trying to part some 3" material about a mile away from the chuck to the machinist here at work. We both laughed, and decided I would be best to let your process evolve on its own without our intervention lmao. At least its just plastic. Now go try that with steel.
#8831
I would not have attempted it with steel. I actually got pretty close with delrin. And if I hadn't gotten overzealous with the cutter pressure I might have won.
Steady rest was like half an inch too small, otherwise would have used that.
#8832
SadFab CEO
Total Cats: 1,142
If you look at the vacant dovetail on that tool post in your pic, you'll see 2 dents, one with the surface pattern ridges from a lathed piece of material. That made some noise and ruined some undies im sure.
#8834
SadFab CEO
Total Cats: 1,142
@concealer404
@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404@concealer404
