Superefficient cooling via geographic location
Old 02-01-2017, 02:29 PM
  #101
G3ML1NGZ's Avatar
Total Cats: 102
alright. I found a supermiata damper used. Am I correct in thinking that all the dampers are identical for 1.6 and 1.8 apart from shortnose and the trigger wheels are the difference when you order them new?
G3ML1NGZ is offline
Old 02-01-2017, 06:56 PM
  #102
Total Cats: 3,128
Yes
sixshooter is offline
Old 02-10-2017, 05:20 PM
  #103
G3ML1NGZ's Avatar
Total Cats: 102
goddamnit.
cleaned the car with a pressure washer (exterior only). Now it stumbles and shuts off intermittently. Coil pack is dry, maf plugs and everything around that is dry. Feels like spark trouble because all other electrics are unaffected and it'll stumble and occasionally make small explosions when fuel dumps unburnt into the exhaust. Any ideas?
It also loses tach signal, motor will be in gear and coasting but tach drops until I get spark again. Coil pack fucked?
G3ML1NGZ is offline
Old 02-11-2017, 07:00 AM
  #104
Total Cats: 3,128
Pull spark plug wires off plugs. There's probably water down in the holes. Pull all the plugs out and free spin the engine for 5 seconds. Replace them and it should run fine.
Old 02-18-2017, 08:11 PM
  #105
G3ML1NGZ's Avatar
Total Cats: 102
Flew over to Orlando, spent an evening with Steve Six-shooter and Troy Miata2fast drinking beers, good food and Miata banter, good guys.
Package days are good days
Can't wait to get home and slap this thing together.
Then I also decided to visit treasure coast Miata and get some parts there. They were really helpful and friendly, do recommend
G3ML1NGZ is offline
Old 02-18-2017, 09:09 PM
  #106
Total Cats: 1,687
I got an awesome bottle of Vodka. Started drinking it tonight. Sixshooter said you are considering coming back for MiataPalooza. If you do let me know and I can get you a MKTurbo shirt when you come hang out at my booth.
shuiend is offline
Old 02-18-2017, 09:52 PM
  #107
G3ML1NGZ's Avatar
Total Cats: 102
Glad you like it, Reyka is my favorite vodka.
April will be a bit hectic at work but I'll do my best to get out there. I really want to experience this festival and meet the rest of you guys
G3ML1NGZ is offline
Old 02-18-2017, 11:35 PM
  #108
x_25's Avatar
Total Cats: 141
Every time I have needed an odd little bracket or part and have called Treasure Coast Miata they have been wonderful.
x_25 is offline
Old 02-20-2017, 11:23 AM
  #109
Total Cats: 3,128
It was nice to meet you and Dori.
It looks like you have a lot of parts to keep you busy wrenching until Summer comes to Iceland.
Thanks for the Reyka, too. I'm saving it for a special occasion.
Lars brought me a Magnaflow so my car is much quieter now, thankfully.
Old 02-21-2017, 06:06 PM
  #110
G3ML1NGZ's Avatar
Total Cats: 102
It was fun to meet you guys too. And I liked the sound of your car.
The block is getting prepped next week and I'll get into a huge tuner garage to work on the car at the same time, so expect a lot more progress from now on.
I secured one of 2 hard tops in Iceland and will be getting it this weekend in trade for my soft top.
What do people recommend to clean the rust off the block before painting it?
Also, the RS intercooler looks like a really good fit if it doesn't interfere with anything on the outside edges.
can't wait to finally start wrenching for real
G3ML1NGZ is offline
Old 02-21-2017, 09:47 PM
  #111
Total Cats: 3,128
I thought my car was too loud. I just installed the big MagnaFlow from Lars and really like it. Quiet and deep...
I'll be selling the old HKS muffler.
That intercooler looks like a good fit if the pipes don't end up at the frame rails.
Old 02-24-2017, 12:20 PM
  #112
G3ML1NGZ's Avatar
Total Cats: 102
Ugh. I bought the Q-max cooling kit from 949 racing. Supermiata radiator and coolant reroute. And the lower radiator outlets interferes with my PS lines. Am I missing something or am I forced to delete power steering?
G3ML1NGZ is offline
Old 02-24-2017, 01:24 PM
  #113
G3ML1NGZ's Avatar
Total Cats: 102
Nevermind, just deleted the cooling loop, won't do me much harm here in the cold.
But my new garage is pretty cool though
and the upper level is just packed with shelf space for parts and tools.
G3ML1NGZ is offline
Old 02-25-2017, 02:13 PM
  #114
G3ML1NGZ's Avatar
Total Cats: 102
This just in... Hardtop!
G3ML1NGZ is offline
Old 02-25-2017, 03:32 PM
  #115
Total Cats: 3,128
Good find on the top. I like mine.
Old 03-12-2017, 06:42 PM
  #116
G3ML1NGZ's Avatar
Total Cats: 102
Tiny update.
car will be repainted in 3weeks.
On Friday I bought a ratchet set because I needed a 12point 12mm socket to remove the head from the motor. On Saturday night I dragged my *** out to the shop ready to be productive.
What are the freaking odds?!?! So I just gave up and went out drinking.
And a bit of tinkering in prep for the painting.
Next week the block is headed for the machine shop to be bored and crank measured for bearings.
G3ML1NGZ is offline
Old 03-28-2017, 06:36 PM
  #117
G3ML1NGZ's Avatar
Total Cats: 102
alright. megasquirt3 is installed and running. It seems like it's not running the alternator, the coolant does not reach full operating temp and the immobilizer is flashing.
It's a rev built unit and the most pressing issue for me is the alternator. Any help is greatly appreciated. I looked but found nothing and I need this asap. Sorry for being useless at this
Edit : So my only way is to build the alternator control circuit?
G3ML1NGZ is offline
Old 03-30-2017, 03:52 PM
  #118
Total Cats: 3,128
If he built it for your car the alternator circuit should already be in there.
Old 04-02-2017, 05:13 PM
  #119
G3ML1NGZ's Avatar
Total Cats: 102
Yup. Just trying to get a hold of him to get the settings I need (if anyone has one of his MS3 units and doesn't mind sharing their settings for alternator I'd love them for it). When I initially tried to use the computer the car wouldn't run and in my inexperience found a map off the net that I ended up getting to kinda work but I'm missing the alternator settings. so that's where I'm at right now.
A garage mate offered me these Honda Enkei wheels for cheep, I like the look, just gotta weigh them before making a decision.
G3ML1NGZ is offline
Old 06-06-2017, 10:22 AM
  #120
G3ML1NGZ's Avatar
Total Cats: 102
Am in the middle of the assembly of the motor, car gets resprayed next weekend. I gave up on my buddy that was always flaking out on doing it and found a reputable guy who'll take the car for a week to do prep work and paint.
I then bought led headlight bulbs. It's a supernova v3 and I'm pretty impressed. Much more light output and the cutoff is nice and clear on the wall 15ft away, so should be no glare blinding oncoming traffic. Too bad I have to wait until September for the sun to set. Won't be able to give a full review until then. The glare you see in the picture is simply because the camera is within the beam
G3ML1NGZ is offline
Quick Reply: Superefficient cooling via geographic location
