TSE EFR NB2 Build Thread
#465
I was looking for a torque spec in the instructions because I was afraid this was going to happen. And it did.
#469
So today I got the snapped bolt out and new set of bolts from Andrew and started completely over. I finished safety wiring to my best ability with the tools I had and am happy with it. This took way longer than I was expecting because the wire that wraps around the first bolt kept on coming up over the bolt head. Those of you that have done this know what I'm talking about.
https://flic.kr/p/RqeCas[url=https://flic.kr/p/RqeCas]
I also drilled out an oil drain plug that I got from auto zone so I could stick my oil temp sensor in there. Hopefully it works.
https://flic.kr/p/SsXRof[url=https://flic.kr/p/SsXRof]
https://flic.kr/p/SsXPvC[url=https://flic.kr/p/SsXPvC]
https://flic.kr/p/SsXLCo[url=https://flic.kr/p/SsXLCo]
I aslo started working on the Skunk 2 TB. All the gaskets and the IACV spacer lined up perfect but there is one screw which is like 2mm too long. Its the short one that is in between the IACV and the Spacer. EO2K, did you have this issue?
https://flic.kr/p/S7SW3d[url=https://flic.kr/p/S7SW3d]
#476
Total Cats: 1,900
![Eek4dance](https://www.miataturbo.net/images/smilies/eek4dance.gif)
