Old 02-14-2017, 02:42 PM
  #8601
patsmx5's Avatar
Total Cats: 519
I would build it overkill to prevent a fuel leak, fuel leak is something I never ever ever want to happen. Three 1/8" aluminum tab in single shear is not overkill enough for me to feel comfortable running that on my car.
Regarding you mentioning another part hitting his fuel rail, I would want my fuel rail beefy enough that if the motor hit it, it would dent the rail or bend the tab, but not crack it. Obviously I won't want anything hitting it in the first place but you get the idea.
patsmx5 is offline
Old 02-14-2017, 02:44 PM
  #8602
Oh I agree. Was just rereading that thread and realized it. I have some thick aluminum at home I'll take a second shot with.
Old 02-14-2017, 02:52 PM
  #8603
Wonder how the plasma cutter will handle 5/16th aluminum....
Old 02-14-2017, 03:06 PM
  #8604
Ya, just look at how strong mazda makes the rail and the mounting for it.
Many other companies, like Subaru, even cover the rail in some insanely thick steel plates, so that you'd have to break the engine in half before you could ever damage the rails or bend/break them in any way.
It's just one of those things that "I can't bend it with my hands" is nowhere near good enough. If it ever leaks, you're gonna have a real bad time.
Old 02-14-2017, 03:08 PM
  #8605
Ours is surrounded by an intake manifold. So that covers quite a few cases. I'll see what thicker tabs look like. Might resort to bolting them on.
Old 02-14-2017, 06:14 PM
  #8606
Total Cats: 2,103
1. buy 1" box aluminum at metal store or Home Depot Motorsports
2. Cut in half, then grind into appropriate shape
3. Weld
4. Please the internet gods
Savington is offline
Old 02-14-2017, 06:16 PM
  #8607
this guy gets it
  #8608
Hmmm. Not seeing it. Space is very tight there. Valve cover runs into everything. I'm just going to try thicker tabs. I have more scrap sheets at home from work.
Old 02-14-2017, 06:51 PM
  #8609
dr_boone's Avatar
Total Cats: 17
it would look like what you have with gussets added only better nice clean corners,
dr_boone is offline
Old 02-14-2017, 06:52 PM
  #8610
I think I understand. I'll see what I have laying around.
Old 02-14-2017, 08:00 PM
  #8611
Better?
Old 02-14-2017, 08:02 PM
  #8612
Total Cats: 558
Yes
sonofthehill is offline
Old 02-14-2017, 08:55 PM
  #8613
Total Cats: 858
FWIW, I had the same aux fuel rail setup as Abe in the original incarnation of the FM2 on my car and the photos are deceiving, the rail doesn't come anywhere near the shock tower brace. This was a vibration/fatigue failure, not an impact one. Obviously the magnitude of the vibrations won't be as large when it's mounted on the head rather than out on the end of the intake manifold, but paranoia is justified here, IMHO. Notice that all of the aftermarket fuel rails around are CNC aluminum with the mounting tabs being big, thick parts of the base material.
codrus is offline
Old 02-14-2017, 11:53 PM
  #8614
2 tabs done. Getting there. I'm stupid and forgot that id1000s are taller than stock injectors. So I need some spacers.
Old 02-15-2017, 11:51 AM
  #8615
Total Cats: 558
Hmmm.
How much are the nice CNC'd ones?
Is this going to be e85 friendly?
How come no one makes them from mild steel?
Uh oh, I have become question boy wait til you see my next thread post.
Old 02-15-2017, 11:52 AM
  #8616
Total Cats: 558
I don't like the tab on the left.
Old 02-15-2017, 11:54 AM
  #8617
CNC ones are cheap. from my research this will be fine for e85. Especially how often I will run it. (almost never)
Interesting read: http://www.horsepowerinnovations.com...le/view/17/81/
Old 02-15-2017, 12:20 PM
  #8618
Total Cats: 558
Thanks! All my questions answered, except why no one does mild steel like the factory one.
Old 02-15-2017, 12:22 PM
  #8619
The mild steel is coated, and requires lots of custom bits. CNC aluminum is as easy as sticking a block of aluminum on a CNC mill and waiting. A mild steel one would require some sort of production line. Which works great at OEM levels of production, but not at aftermarket fuel rail levels.
My guess at least.
Old 02-15-2017, 12:24 PM
  #8620
Total Cats: 558
Sounds reasonable.
