help with tune
Old 02-12-2017, 04:21 PM
powellke's Avatar
Default help with tune
I just picked up my 97 with GT2554, MS1.5PNP, DO methanol injection, Ford 400cc injectors in December and I'm finally getting around to trying to figure out what is causing the POP POP POP at high boost, near WOT. I noticed in the data log today that around 5000 RPM, WOT, the AFR jumps from around 12 to 17-19 and the RPMs wiggle. (don't know proper terminology) That's when the popping starts. I'm attaching some screenshots of the log, the raw log file, and the msq file. Any advice would be appreciated.
File Type: msl
File Type: msq
powellke is offline
Old 02-12-2017, 05:06 PM
Onyxyth's Avatar
Total Cats: 62
You're definitely running out of fuel at the top end, 12.8 is leaner then i'd run at 200 KPA.
Overboost protection on? Spark blowout? (what coils/plugs are you using)
Onyxyth is offline
Old 02-12-2017, 05:18 PM
powellke's Avatar
Overboost protection is on but it did the exact same thing when I used a manual boost controller instead of the EBC. I don't know about spark blowout or what coils/plugs are in the car.
powellke is offline
Old 02-13-2017, 11:19 AM
Frenchmanremy's Avatar
Wouldn't spark blow-out cause a rich condition? Not a lean condition?
Unburnt fuel going into exhaust would cause the pop-pop, but you'd read rich.
You seem to be leaning out quite a bit.
I may also be talking out of my ***, someone correct me if i'm off my rocker.
Frenchmanremy is offline
Old 02-13-2017, 11:56 AM
phil21191's Avatar
Total Cats: 12
Misfires always show as a lean condition,
phil21191 is offline
Old 02-13-2017, 12:01 PM
Thumbs up
Can you help me understand that?
AFAIK, a misfire is caused by the spark not lighting the fuel, causing unburnt fuel to go into the exhaust. This would be picked up by the O2 sensor as too much fuel, causing a rich situation.
I'm not debating, but trying to comprehend why I'm wrong.
Old 02-13-2017, 12:05 PM
phil21191's Avatar
Total Cats: 12
O2 sensor measures Oxygen content rather than fuel content. So it'll see the cylinder(s) full of air leaving the exhaust rather than the unburnt fuel
Old 02-13-2017, 12:07 PM
Thank you for clearing that up! Have a cat!
Old 02-13-2017, 11:13 PM
powellke's Avatar
If I'm running out of fuel on the top end, is that something that can be resolved with a tune or will it require upgraded injectors? More than the 400cc ones I have now.
powellke is offline
Old 02-13-2017, 11:57 PM
Onyxyth's Avatar
Total Cats: 62
More injector AND more fuel pump. You're at 90%+ duty cycle near the top, which means your injectors are maxed out. If you're running the stock fuel pump I bet it's also near its limit. Especially if it's old.
Onyxyth is offline
Old 02-14-2017, 12:08 AM
powellke's Avatar
According to the previous owner, it has a Walbro 255HP fuel pump.
powellke is offline
Old 02-14-2017, 11:00 AM
How much boost are you running?
I'll be running 700cc injectors with a stock pump on stock wastegate pressure with a no electronics kit from FM (2560R)
Will I be running into the same issue?
concerned...
Old 02-14-2017, 07:49 PM
powellke's Avatar
I'm running 14psi.
powellke is offline
