01 VVT Turbo build
01 VVT Turbo build
Good evening!
I have an 01 VVT, and building an MS turbo setup. I have been reading the forum for a few days now, and I am in complete confusion.
My question would be, could someone please help me, which diy megasquirt kit do I need to be able to control VVT, turbo and keep my AC too. I am pretty advanced in soldering, not afraid of assembling the MS. Also would like to know, what exactly need to get, to be able to build a plug in ECU, what sensors and modifications needed and so on. Yes, Ive searched, and yes, I am more confused than ever.
Thank you for helping me out!
Barabas
Barabas
My vote is for MS3 Pro Module and Franks adapter board. Cleanest install. Even cleaner than a MSProPNP.
https://www.miataturbo.net/megasquir...-boards-86884/
Y yo no hablo aleman, mein herr.
Well I pulled the trigger on main engine parts today. Wiseco pistons and rings, king bearings, arp head studs, cometic head gasket. Other parts are getting ordered once the machine shop matched the bores and got the engine built. Now to shop for megaSQ. Let's start reading all these helpful links.
EXCITED!
EXCITED!
I like that, but cant quite understand. So I just buy this:
https://www.diyautotune.com/product/...th-black-case/
And it fits into franks board?
So, here's the list of stuff you need, from the other 2 links and now all you need to do is price + buy + build = enjoy life.
https://trubokitty.com/#/ms3xassembly
You had the best advise in the 2 posts linked. If you're looking at MS2 then you won't get much help on this site because everyone either has or plans to move on to the MS3 based. Franks stuff is nice and has some good features but is overkill I'd guess for you.
So I built the Jimstim and built the daughter board. Was wondering if the jimstim should be lighting up without being connected to the MS board as I turn it on. Didnt dare plugging it in yet...
Tried, the LEDs aren't working either from the test. Somebody?
On the expansion board connector side there is two times X 24. Means I should solder two wires on the same connector?3ULow Battery Warning LightX - 24White/Red 2NVariable Tumble Control System (VTCS)X - 24Lt Green/Blue
Found I need x24 three times?? I cant get 3 wires on one pin...
VVT
X - 24
NTRS1
VVT
X - 24
NTRS1
