Singular Motorsports ECU Brackets
#121
Total Cats: 1,222
Update on these, seems like nearly every one of these brackets that gets ordered is for a Reverent ECU and so needs the adapter dabs as well. As a result we ran out of stock on those tabs so a couple guys have been in a holding pattern waiting for us to finish more tabs.
Those are being finished this week so existing orders that need the Reverent tabs should ship beginning of next week, and future orders needing the tabs will be back to shipping immediately.
#122
#123
Less (projected) demand. The more complicated the solution needs to be, the more demand there will be for a well-designed solution that takes the guesswork out of the process for the customer and makes it a bolt-on affair. Of the three ECU locations, the 99+ is the worst/most difficult to mount an aftermarket unit, followed by the 90-93. The 94-97 location is much easier for a DIYer to mount an ECU in, by just screwing it into the rear bulkhead. I'm not saying that's a good way to do it, but because it can be done that way easily, less guys will opt to spend money on a dedicated bracket.
94 R package owner here. I've got a REV Basic MS3 I received around November of last year. Currently, the ECU is just stuffed behind the passenger seat, with the seat holding it in place.
I know you mentioned a low projected sales volume, but I'm interested. Keep the price below $150, and I'll send you the cash today. I want to keep it in the OEM location, and while I could fab up a bracket, I'd prefer to buy a nice, pretty, production style one.
EDIT: I also fear water/snow for a foot-well mounted ECU. Plus all my wires are already cut to length and will likely not reach the footwell.
#128
Finally some updates!
Reverent ECUs:
We've worked everything out for the Reverent Enhanced ECUs. Now when you order one of the ECU brackets through Good-Win Racing, just put a note during checkout that you need the tabs to fit the Reverent ECU and we'll throw them in the same box. No extra cost.
1999-2005 ECU Bracket:
It's here!
Built to fit your aftermarket ECU in the factory location under the dash of the NB miatas. Accommodates all the same ECUs as the 90-93 version; AEM, Megasquirt, MS3 Pro, Adaptronic.
Singular Motorsports Miata ECU Bracket for '99+ for Miata 1999-2005
Here it is, finished in our new "Chrome" powdercoat which is now standard;
1990-1993 Bracket Updates:
The early-model brackets also come standard in our new powdercoat now:
Singular Motorsports Miata ECU Bracket for Miata 1990-1993
PRICE Updates:
So we've added more features to the brackets... price needs to go up right? Nope!
We've been working to streamline the production process for these and keep our costs under our target. This has allowed us to DROP the price to $59 for both ECU models! The new pricing is live on Good-Win Racing.
-Ryan
Reverent ECUs:
It's here!
PRICE Updates:
-Ryan
I have a 2005 RHD Miata will this bracket fit?
#129
I ordered one of these for my Rev. MS3 basic going into a 00 model. I've had my ecu for awhile and I guess it was an early larger unit and it wouldn't fit as is. I made a cutout on one end for my pin connector and a few tiny zip ties on the other end to tie the adapter to the mount and it works. With those mods it fit well and is a much better solution than just stuffing the ecu under the dash with huge zip ties around the steering column. Even though it wasn't a direct fit, I am really satisfied with the set-up. It is a well made product I would buy again.
#130
That is a very cool piece. It appeals to my OCD for sure. Doesn't matter if it's hidden.
I fabbed up something similar to get the ECU up off the floor.:
If you want the bolt pattern for the Haltech Elite 1500, and Elite 750/550 I can send them to you if you'd like to add those to the plate if there is room.
#131
Before I try to drill into it...
Are the NB brackets incompatible with the DIY MS3? I have a brain built unit and I don't think it fits. I mean, I don't think I'm that spatially challenged haha.
#132
Total Cats: 1,222
There are holes provided for the DIY PNP, MS3 Pro, Reverent built MS3, AEM EMS-4 and Adaptronic E440D, but that doesn't mean other ECUs are entirely incompatible. If your DIY MS3 has a different footprint and that's all that keeps it from bolting up then by all means, drill away!
#134
Jokes aside, ill see if i can find some screws that drill through. The box is too wide to fit under the shelf as well.
Please post here when you figure out a decent way to get it mounted!
#135
Total Cats: 1,222
That part of things is a bigger hurdle than the holes. If the ECU case is too tall to fit under the shelf of the bracket, that means it probably won't fit under the dash in the factory location - that shelf on the bracket pretty much butts up against other hard parts under the dash.
#136
#137
@ThePass
I think this is the case that my ms3x came in. Images from DIY Autotune. As you can see, it mounts underneath in the footwell but the case is a bit wider than the oem bracket. I just wanted to confirm that you hadn't tested this one in your setup as we'd discussed previously on this thread.
Thank you!
Thank you!
