jtothawhat is about to bust a 1.6
#470
Total Cats: 51
probably only makes 50 ftlbs till 5500 when it starts to spool, then jump 500ft lbs in 500rpm. lol
interested in seeing it. this cars been in the build stages in the same amount of time I built my Miata, parted it out and have been out of a Miata for 5 years. :P
#474
UPDATE!!!!!!
Car's on dyno now, they're tuning still but so far revving to 7,000 RPM made 365 whp on a Mustang Dyno off the wastegate spring only roughly 16 pounds of boost with the power still rising. The tuner said 8,200-8,500 should be about where the power will drop off. He's estimating 375-ish whp off the wastegate, 550 whp with higher boost levels, the turbo is limiting factor.
Will post videos/dyno sheets once I get them.
#477
Total Cats: 1,685
![Name: Miy6Is8.jpg
Size: 828.0 KB](https://www.miataturbo.net/attachments/build-threads-57/237270d1683055230-jtothawhat-about-bust-1-6-miy6is8.jpg)
