Trackspeed's '02SE "Acamas" - EFR6758, TSE motor, 500whp or bust
#403
Total Cats: 2,102
I like this one, it looks a lot more legit: https://www.efihardware.com/products...head-terminals
Permatex had a Hylomar product but it appears to be NLA or superceded. Can anyone think of a reason why standard Permatex PTFE goo wouldn't do the trick?
#407
Gasoila E-Seal is a specifically E85-rated thread sealant with PTFE.
https://www.amazon.com/Gasoila-Seal-.../dp/B00CRKVI4S
#409
Total Cats: 2,102
Ordered up a bunch of small bits and wire this morning. 10awg Tefzel wire, DR25 heatshrink, ring terminals, and a single 25A 2-pin Deutsch connector so I can assemble the bulkhead terminals and then never touch them again. I haven't found the fuel pump connector yet - I'd like to buy it in connector+pins form so I can crimp my own wire in. I didn't see it in the connector witchhunt thread, though.
#410
I bought a the 2 pin connector for 10gauge wire. Let me find where I got it.
Edit: Didn't realize you wanted the stock connector. Can't help you there. I just chopped the 2 wires I needed off. Didn't want to touch the signal wires for level.
#411
Total Cats: 2,102
For me, the killer was the thought of listening to an external 044 screaming away. Not street-car friendly. Same reason I'm trying to use a DW300 at near-max capacity instead of going to a louder Walbro 450.
#412
Thanks for pointing this out. The form factor of yours makes it a little awkward to incorporate into the harness. How about this: DST2045AX Littelfuse Inc. Discrete Semiconductor Products DigiKey Nearly the same specs but easier to drape across two wires and solder into place.
The part I linked is meant to be mounted on a heatsink. This kind of heatsink will probably work:
531202B02500G Aavid Thermalloy | Fans, Thermal Management | DigiKey
#414
Total Cats: 2,102
That's a cute diode (I had to look up who Littelfuse ate to acquire their diode business!), but the problem is you can't get the heat out of the package. It's rated at 20A only at 25*C and with a PCB with copper area pulling heat out of the legs. It will overheat at only 5A average or so.
531202B02500G Aavid Thermalloy Fans, Thermal Management DigiKey
I am definitely going to put all of this together into a kit. It shouldn't be nearly this hard
![](https://www.miataturbo.net/images/smilies/smile.gif)
#416
Total Cats: 2,102
Starting to wire things up. I have the FPR and filter mounted but I'm waiting on some sleeve to protect the fuel hoses as they squeeze their way down past the tank before I start plumbing.
SSR will sit on the passenger side of the car, flyback diode will sit on the driver's side. The flyback ended up being kind of a bulky thing - I didn't have any good solution for splicing a trio of 10awg wires, so I grabbed some spare 12awg and I'm going to connect it to the pump at the bulkhead. That means four wires up to the tank instead of two, but oh well.
Dedicated fuseholder just after the battery will hold a 25A fuse. I even managed to get the wire tucked in with the OEM terminal cover![Party Kitty](https://www.miataturbo.net/images/smilies/birthday[1].gif)
![Name: ODrtinJl.jpg
Size: 49.7 KB](https://www.miataturbo.net/attachments/build-threads-57/233261d1683053412-trackspeeds-02se-acamas-efr6758-tse-motor-500whp-bust-odrtinjl.jpg)
![Name: e9WNzBml.jpg
Size: 54.8 KB](https://www.miataturbo.net/attachments/build-threads-57/233262d1683053412-trackspeeds-02se-acamas-efr6758-tse-motor-500whp-bust-e9wnzbml.jpg)
#418
Total Cats: 2,102
Interesting, I must have mixed it up with the 044 WRT noise. Radium has a test that says that it's quieter than the Walbro 255 (although that's not a good benchmark either). It's not hard to switch pumps later - just a pigtail swap since I'm wired with 10awg already. It's worth knowing where the DW300 taps out.
