Ryan's build thread - Clean and Mean
#461
Total Cats: 3,132
BTW, I got vertigo really bad the evening after we pulled the engine and it hasn't let up since, for those who are wondering. I can't walk straight or drive right now, FTL. Undiagnosed cause at present, but I think it is vestibular neuritis from the symptoms.
#462
Total Cats: 217
Oh poo. I was hoping you would be able to lend a hand this weekend. I will need to stop by your place at some point this weekend to pick up the clutch alignment tool since I still cannot find mine. I will likely do this tomorrow since I am off.
#463
Don't wait! I'm all cooped up being out of work and need things to occupy my mind. Show current progress!
Feel better :/
#464
Total Cats: 3,132
Edit: I can probably still help but I can't drive over there myself at this point. It's ok to fall into a wall or crash into a door facing but not so good to drive into a pole or parked car.
#465
Total Cats: 217
So what you're saying is that I'm going to have to pick you up for help and then get drinks with you at the brew hub on the way back. You know, because while I'm up there....
#468
Total Cats: 217
As Sixshooter pointed out, we removed my motor to fix oil leaks from the oil pan and rear main seal.
Then we had to disassemble some things.
Old clutch disc was all gunked up and oily from the leak in the rear main seal. I pushed the seal in too deep which caused it to leak. Rookie mistake.
Now we had to clean up all of the mess from the leaky oil.
Then everything was reassembled.
I also took this opportunity to add some heat shielding to the transmission tunnel.
I am planning to put the engine back in the car tomorrow with Sixshooter's assistance. I have also take this opportunity to install another part that I have had sitting around for way too long...
I will be cutting into my hood at some point this weekend and there will be no going back
#470
Total Cats: 3,132
I'd consider adding some of that reflective shielding here as well. And do something to protect the underside of the fuel tank from the exhaust at some point. I had boiled my fuel before I shielded mine. The factory setup protects the tank with a shield over the pipe back there.
I wish I felt better and could come help today.
#471
Total Cats: 217
I've made some good progress so far this weekend. I had the joy of getting the motor and transmissions back in the car by myself. I have always had a hand in my past so this delicate solo dance was a new experience. After a little trial, error, and advice from sixshooter I was able to figure out the best way to finesse the motor into the car.
Then I proceeded to begin reassembling everything and I made pretty good progress.
I have tomorrow off and should be able to finish it up then. I just need to get the hotside, intercooler piping, and some bracing back on before adding all of the fluids. Then she should be good to drive! I am going to take this opportunity to wire up the EBC for the EFR as well. I also still need to cut the hood vents.
#474
Total Cats: 217
The singular motorsports vents have testing to back up their efficiency. They should flow more air out off the hood.
#475
Total Cats: 3,132
Yep, Singular vents have a greater opening size for more volume. Ryan's car has a garage and I was concerned about torrential rain we get most summer afternoons getting on top of the engine on mine. Subaru vents made a significant difference on track for me. I'm sure the Singular vents will be even more productive. Ryan's car is heavier and will make more power with a smaller radiator capacity so I think it is a good match for him. He also hasn't added an external oil cooler yet, though he has purchased one. He will make use of the venting capacity.
Ryan, FYI, I'm eyeballing Sebring on January 7-8 with NASA, Miami-Homestead on January 22, and Road Atlanta in March with PDG.
#476
Obviously they're a fantastic option because they work. I was just curious because sixshooter did it and has log data showing the difference.
#477
Total Cats: 3,132
Singular are very high quality. Subaru were less expensive and something new I was inspired to try. I liked the way they looked. I would let the needed capacity and practicality in your situation drive you as it did each of us.
#479
Total Cats: 217
I finished putting the car together and filled all of the fluids on Monday evening. I went for first start up and there was a huge backfire after about 3 cranks. It scared me and I stopped cranking. I was already cleaned up for dinner so I wasn't in the mood to trouble shoot it then and just decided to look at it today after work. Turns out I'm just a ***** and it was leftover fuel or something. Fired right up on the first try. I let it run and burped the coolant for a while. I didn't see any leaks so I turned the car off. I was just about to put the undertray and bumper back on when oil started dripping on the ground as I was underneath the car. Sourced the leak to one of the threaded fittings on the passenger side. The engine was hot as **** so I'll take a look at it tomorrow.
Decided now was a good time to hook up the EBC and then take a look at my driver side headlight that went out. For the headlight I thought one of the HID components went bad because it's a cheap kit. Swapped the bulbs and it worked just fine on the other side. Then I swapped the entire HID assembly and only the passenger side worked still. ****. There is something wrong with my stock wiring. I am pretty sure it's a ground somewhere because the headlight will flicker on and then quickly fade out after a half second. Anyone know of any common problems I should look for or is this going to be a wild goose chase into the factory wiring?
#480
Total Cats: 217
Fixed the oil leak. My oil feed line for the turbo wasn't tight on the fitting on the passenger side. I also fixed the headlight. It was just a blown fuse. The undertray and bumper went back on the car and now all that is left is the hood vents. Super excited. Looks like I might actually make it on the track this time.
