Old 11-26-2016, 04:00 PM
  #8121
Currently working out all the wiring for the swap.
I need the following new connections. Everything else stays the same on my current harness.
TPS
Knock
VVT
Crank
Cam
VICS
I have connectors for all of these, but I have had wires break on old connectors so I will be purchasing new pins, depining the old connectors, and putting new pins and seals in. Instead of buying a whole bunch of new connectors.
Anybody have a reason I shouldn't do this?
Old 11-26-2016, 04:16 PM
  #8122
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Aidan is loud, and definitely on the loose side. These are perfect for him.
hi_im_sean is offline
Old 11-26-2016, 06:11 PM
  #8123
EFR water fittings. I thought I had read people having issues finding them.
Can I not just run one of the many M14x1.5 to AN6 fittings I find on ebay/jegs? Seems like there are tons.
Old 11-26-2016, 06:26 PM
  #8124
Total Cats: 1,184
Buy a vvt engine harness, carefully crimp it to your engine harness. It's incredibly clean, and makes engine pulls very easy. A lot of work, but essentially converts your engine harness to nb.
curly is offline
Old 11-26-2016, 06:27 PM
  #8125
I have one. But I'd rather just add 2 wires than do that. If I'm doing that much rewiring I'm going to get bulkhead connectors and wire from scratch.
Old 11-26-2016, 07:02 PM
  #8126
Total Cats: 1,900
M14x1.5 with copper crush washer -> AN6 male, then use whatever AN6 fittings you want. It's working fabulously for me. If space constrained, forged AN6 90 will save you some space over the tubular longer radius 90 or whatever angle you need, but I see very few reasons to buy the ultra expensive low profile reduced diameter banjos unless they are actually needed.
But again, its all about space and how much you have to work with.
EO2K is offline
Old 11-30-2016, 10:09 PM
  #8127
Thanks @Savington for the oil cooler bits. Going to start a new setup with the giant setrab I got from ebay.
Also picked up some gates stuff for timing
Old 12-01-2016, 01:00 PM
  #8128
Total Cats: 3,075
Paging Aidan to the old Ford colored courtesy phone -
sixshooter is offline
Old 12-01-2016, 01:02 PM
  #8129
Ah man if it were a truck I would buy it for sure.
Old 12-03-2016, 02:17 PM
  #8130
Total Cats: 2,103
I wouldn't go narrower than .004 on a 2618 piston, regardless of the noise. With STs you can run smaller and not worry because of the alloy. My DD (Acamas) has Supertechs and it's no louder than a stock engine on startup. I light it off and go immediately, just like I would on a stock engine. Just stay out of heavy boost until the EBC turns on at ~160*F.
Savington is offline
Old 12-03-2016, 02:18 PM
  #8131
Thanks. Thats what I've seen.
I did that on my stock 1.6 as is, so not really an issue for me, heck i don't drive any of my cars hard cold. Especially with the special 200*F thermostat
Old 12-07-2016, 12:58 PM
  #8132
What a great way to spend a Wednesday morning before work.
Old 12-07-2016, 10:29 PM
  #8133
farpolemiddle's Avatar
Total Cats: 95
You ever make any progress on that fastback group buy you were messing with?
farpolemiddle is offline
Old 12-07-2016, 10:31 PM
  #8134
Not really. Got too many other financial commitments right now. And if I wasn't buying one, then I wasn't gonna organize it.
Also never heard much from CCP. Still haven't seen anything.
Old 12-08-2016, 12:44 AM
  #8135
Scaxx's Avatar
Total Cats: 884
I think they learned from the lessons of others in just taking their time to do it. Maybe they'll release it, maybe they won't. I hope they will, but only time will tell.
Scaxx is offline
Old 12-08-2016, 12:47 AM
  #8136
I'll have one eventually. Just not right now. Maybe next winter.
Old 12-08-2016, 01:15 AM
  #8137
Scaxx's Avatar
Total Cats: 884
You and me both, one of these days. ****, if oe hardtop prices keep rising I may be able to afford one just by selling my hardtop haha
Scaxx is offline
Old 12-08-2016, 01:19 AM
  #8138
ughhhhhhhhhhh that snow looks awesome
Old 12-08-2016, 01:33 AM
  #8139
It was amazing. 6* out. Freaking cold. But the snow was so good. About 2-3 feet of fresh over that last couple days.
Hailey is about 9 days in and already killing it.
This was from out last time up. Haven't had better days at hood in years.
Old 12-08-2016, 01:58 AM
  #8140
Scaxx's Avatar
Total Cats: 884
Haven't been up to the mountains since I started school, maybe I'll make it up this year. Makes me wanna go so bad
Scaxx is offline
