Fabulous Fabrication Post all your custom fabrication projects here; impress all your friends.
Buying a welder
Old 09-16-2016, 11:03 PM
  #381
elijah_mckay's Avatar
Total Cats: 7
Originally Posted by afm
Just upgraded to an Alpha TIG, largely based off this thread. Ordered on Amazon for $690, and it showed up the next day.
I'm really psyched to start using it for its inaugural master cylinder brace project.
Please update when you start using it! I'm planning on getting one of these soon (though I have 0 welding experience) and would like to see how it performs for someone who actually does have some experiences.
elijah_mckay is offline
Old 09-16-2016, 11:38 PM
  #382
2manyhobyz's Avatar
Total Cats: 42
[QUOTE=Leafy;1347262]yup tig finger is awesome.
+1
Givem the finger - Tig Finger that is
Anything you can do to make yourself more steady is a plus.
2manyhobyz is offline
Old 09-17-2016, 01:22 AM
  #383
williams805's Avatar
Total Cats: 27
Alpha tig is the ****. I love this thing. Buy and no regret. Do it.
williams805 is offline
Old 10-24-2016, 11:05 PM
  #384
Joseph Conley's Avatar
Do you still feel this way?
Does anyone else who's owned this machine for awhile want to weigh in?
Joseph Conley is offline
Old 10-24-2016, 11:07 PM
  #385
Old 10-24-2016, 11:24 PM
  #386
Thank you. It also looks like the 2016 version has some improvements over the 2015 version. Anyone have the 2016 version yet?
My bad. Looks like both of you have the 2016 version.
Old 10-25-2016, 02:26 PM
  #387
Total Cats: 1,684
I ordered me a Hobart 140 Mig welder today. I love Amazon prime and 2 day delivery, it along with wire and nozzles should be here Thursday. I will pick up a tank of gas in before the weekend. It should be interesting learning to MIG after already knowing how to TIG. I am looking forward to how easy it should be to tack weld exhaust pieces together under the car though.
shuiend is offline
Old 12-05-2016, 01:58 PM
  #388
My Alpha tig finally showed up. I figured I would break it in by building a log manifold. Having never tig welded before or built a log manifold I am pretty happy with the results. I already know several things I will change when I do it again.
Old 03-15-2017, 03:37 PM
  #389
Colipto's Avatar
Total Cats: 28
I am glad this thread exists. I have been planning on getting a welder for a long time now to do some fabbing of my own, looks like the Alpha TIG has my money very soon.
So many thing i want to do with this.. Honda Intake manifold, welding my intercooler pipes to get rid of couplers, endless possibility.
Colipto is offline
Old 05-25-2017, 09:08 PM
  #390
AlwaysBroken's Avatar
I have been lurking this thread on and off for the past year.
I just bought The Procedure Handbook of Arc Welding 14th Edition and am now examining my options for tig welders.
I want to weld up a fresh set of intercooler pipes because the current set are 15 years old and although they work decently, I am not running the same turbo or intercooler I started with, so nothing quite lines up right.
I guess a cheapish welder pays for itself over the course of one or two medium sized projects. Is the Alpha 200 still the best bang for the buck?
AlwaysBroken is offline
Old 05-26-2017, 12:04 PM
  #391
portabull's Avatar
AlwaysBroken: Is the Alpha 200 still the best bang for the buck?
yes
portabull is offline
Old 09-25-2017, 02:04 PM
  #392
portabull's Avatar
so if you have a tig welder with approximately 13' of line (alphatig 200sx), here's a leather cover for your torch line. it has a zipper, not that crappy velcro. i'm happy with mine and i recommend it.
AP-9006Z TIG Cowhide Leather Welding Torch Cable Cover 12' Long 4" Wide w/Zipper | eBay
Old 12-03-2017, 07:10 AM
  #393
Zsanz's Avatar
Total Cats: -11
Nice a weld thread.
Pretty critical application for your first weld.
I would recommend checking the inside of the log for sugaring correct me if i am wrong but this does not look like it was back purged. Furthermore check your gas flow, torch setup, and cleanliness to avoid the brown dust. Lastly, definitely some craters present at your downslopes, if you lift off the pedal slow and continue to feed at the end of the weld you won't get these, they are stress risers.
On topic I use a Miller Dynasty 350 Water Cooled for my GTAW welding, kinda overkill for the home fab guy.
https://www.weldersupply.com/P/376/M...sty350ACDCTigS
However, if anybody needs critical TIG welds, and / or $0.02 on weld set up, material selecton, weldment geometry , what amperage, what angle to grind my tungsten, what gas cup blah blah blah.
I know a few things about a few things welding
Zsanz is offline
Old 12-03-2017, 11:18 AM
  #394
Looks like a mild steel manifold. Sugaring wouldn't be an issue.
I would check the inside for penetration.
Old 12-03-2017, 02:09 PM
  #395
Originally Posted by Zsanz
Nice a weld thread.
It was, and a year later and 10k street miles its still holding up. If it cracked tomorrow I wouldn't be upset. No back purged but its mild steel so I didn't feel it was worth the effort. I believe the brown dust is simply rust. I was welding in a garage heated by a kerosene heater and in my experience, everything rusts fast in that environment. You're definitely right about the craters, total noobness apparent there. After everything was welded I made a second pass over areas with craters.
Like I said in my original post, it was a great learning experience and there is a lot I will do differently on the next one.
Old 01-01-2018, 12:01 PM
  #396
2018 AHP Alpha is on preorder on Amazon for 680.... Is this a good price? What else do I need to actually start welding besides metal and filler rod?
Old 01-01-2018, 12:07 PM
  #397
Total Cats: 104
You'll need a tank of pure argon. Go to your local welding gas place and buy the biggest one they'll let you., probably 80CF.
You'll also need a welding helmet, get a nice one the first time, you'll hate the cheap ones and end up just buying a nice one in a couple months.
Welding gloves I like baby goat gloves mcmaster for normal use, and deer skin for delicate work. Supposedly the new HF tig gloves are actually pretty nice now, never tried them.
You should buy a welding jacket too so you can lean on your work without burning yourself, melting your cloths to you, or catching your cloths on fire. And you really should have all your skin covered when you weld anyways because of the uv light. Sun burn from welding is no fun.
Tungsten, just start with 3/32" thoriated for now it'll work for basically anything (even aluminum, disregard what everyone says).
Leafy is offline
Old 01-01-2018, 12:57 PM
  #398
Anything else you need in terms of accessories for the welder itself?
Old 01-01-2018, 01:02 PM
  #399
Roda's Avatar
Total Cats: 316
Gas lenses are a nice upgrade.
Roda is offline
Old 01-01-2018, 01:44 PM
  #400
Art
Art's Avatar
Total Cats: -251
Art is offline
Quick Reply: Buying a welder
