Is AEM Infinity a piece of junk? Lets find out together!
Total Cats: 268
Starting this thread because I think it would be useful to have all the information in one thread, instead of my build thread.
Yesterday I purchased an AEM Infinity 30-7110, which is Infinity 708, but plug and play for 03-06 350z. It was much cheaper than a regular Infinity 708 and my hope is that they are exactly the same minus the base map.
There are so many
AEM sells 5 different versions
See more: http://www.aemelectronics.com/files/...tion_Guide.pdf
Thereality rumor is that there are really only TWO different ECUs: 5 series and 7 series, with different features simply locked out via firmware.
vs
Is it better than a Megasquirt?
Stay tuned!
The general consensus is that the previous AEM ecus were crap. Since the Infinity hardware and software is not actually made by AEM, there's hope. The AEM documentation, which they wrote themselves, is rather awful and is full of spelling mistakes.
So, who REALLY made it?
The Infinity series ECUs were designed by Enginelab - https://enginelab.net - a small company out of Boulder, Colorado. AEM licenses them and sells them as their own. EngineLab website contains a lot of documentation, arguably better than that of AEM - see https://enginelab.net/documentation/
The AEM software is also based on EngineLab EL Console, which is available for free from https://enginelab.net/downloads (after you register)
What are those connectors?
The connectors are Molex MX123 series. These connectors are used on GM ECUs so there are plenty of places to buy them.
AEM also sells pin kits, but they are overpriced. I bought mine from Home - Current Performance WiringCurrent Performance Wiring - see blue and gray
Another place is from EngineLab - which does not require a crimper and includes a whooping 600 ft of wire - https://enginelab.net/product/el010-wk/
The blue connector for Infinity 5 is different from the blue connector on Infinity 7. I believe its an 80 pin connector
Finally, the connectors are well documented - https://enginelab.net/documentation/...tor_1_Pin_List
There are so many
- Infinity 506 (aka Infinity 6) part # 30-7106
- Infinity 508 (aka Infinity 8h) part # 30-7108
- Infinity 708 (aka Infinity 8) part # 30-7101
- Infinity 710 (aka Infinity 10) part # 30-7100
- Infinity 712 (aka Infinity 12) part # 30-7111
- Infinity 708 for VQ35 part # 30‐7110
- Infinity 710 for VQ35 part # 30‐7107
- Infinity 708 for Porsche/BMW/zee Germans part # 30‐7109
- Infinity 710 for Porsche/BMW/zee Germans part # 30‐7105
The
vs
Stay tuned!
Total Cats: 2,104
I tuned a K24-powered S2000 on an Infinity box and was pretty impressed. The closed-loop AFR control is going to blow your mind - you almost don't have to tune the fuel map, the corrections are that fast and that good. I had every intention of doing a PnP harness for 99-00/01-05 Miatas until AEM refused to give me exclusivity on the trigger pattern I was going to essentially develop for them to get the car to run on stock triggers.
Bad move on their part. Realistically how many units do you think you would have moved a year?
Total Cats: 268
More findings
AEM "Infinity Tuner" is nothing more than an older version of EL Console. My guess is that the AEM development follows EL Console releases and lags behind by a release.
Infnity Tuner: 96.8492
EL Console: 97.8431
AEM include several plugins for some things. These plugins, labeled Wizards in Infinity Tuner, is how you change the regular settings
EL Console however exposes the "Channels" - which is the bread and butter of Inifinity/EngineLabs ECU processing. InfinityTuner hides the channels and does everything through "wizards".
I suspect the wizards can be imported into EL Console since they are just plugins. I looked, and the wizards are written in C#. This means they can be easily reverse engineered. I've done a lot of C# so this is familiar territory for me.
EL Console: 97.8431
Total Cats: 268
Also AEM uses SQLite for storing configuration settings for the wizards. It potentially could be super-easy to add Miata
Total Cats: 361
I've watched engines kill themselves over a bug in the Infinity, which to my knowledge, is still unresolved. There's another bug that causes the ECU to lockup, and because the ECU also has battery power on it, you need to disconnect the battery for it to recover. A significant feature of the ECU only works if you connect it to a hardcoded input. Another significant feature (much needed in the drag racing scene) would randomly completely shutdown one or two cylinders on a 5+ cylinder engine, and had gone unresolved for 4 years.
Also, the AEM support stuff are pretty pathetic. I was once called in to solve a non-starting car (it was on a freshly installed AEM EMS-4). The car would not get initial sync on a 60-2 trigger wheel. It would calculate RPM every now and then but it would not get a constant sync. For giggles, I brought a Universal MS3 in, connected power, ground and signal. It would also not sync. I watched the composite log, and measure 59 teeth instead of 58. I counted at least two more times, 59 every time. So I entered 60-1 in the TS settings, and sure enough, it synced perfectly. The AEM tuner emailed AEM, and - you better believe this - this is their answer (to the best of my memory as it was couple of years ago):
This can't be a 60-1 wheel because we have never seen one before. There is probably some other error, and the MS ECU is only able to sync up with a 60-1 setting because there are too many teeth and the MS has a slow processor, so entering more teeth somehow compensates for that.
No solution was given or any idea as to why the EMS-4 is not syncing. The customer ended up removing a tooth as the EMS-4 doesn't have configurable generic missing tooth wheel settings.
Total Cats: 268
You guys have at least 3 months to talk **** about AEM because that's at least how long it'll take for my car to run. So pace yourselves!
There is no such thing as a hardcoded input if you are using EL Console. The AEM software simply hides the channels interface. I can see there being tons of bugs but unlike most people who want a plug and play solution, I know what I'm doing.
I am also interested in what you find out.
I don't know if Engine Lab did this for this guy, but the conversation is about a year old.
gemellocattivo.com ? View topic - EngineLab/AEM ECU
A couple of quotes bellow:
So the whole AEM infinity line is of EngineLab design and based on the engineLab code system. If you buy the AEM hardware and ask Jim nicely he'll set you up with access to the engine lab system at no charge and you can reprogram the ECU to do whatever you please. He told me all the 2 connector units are the same and have 12 fuel and 12 spark drivers, I'd just need to buy one and start programming it....very very tempting
What I was told the gen 1&2 are completely different from the infinity. The AEM interface on the infinity is very clunky and the control logic appears state of the art circa 1995 so probably very similar to what you are familiar with.
What the EngineLab interface does is basically wipe out everything AEM other than the name on the case and return it to EngineLab. In that state the underlying machine code is in place to read a crank and control injector, coil, and other drivers but there is no control logic at all, I would need to create all of that.......but as luck would have it I've spent a great deal of time over the past 4 years doing just that for my o5e ECU project but kept getting stuck with low level machine code issue....which are all solved int eh EngineLab setup.
Total Cats: 268
Ok we have our first fail, or maybe a win depending on the outcome
Which wideband O2 sensor does the Infinity ECU support?
Edit: read more about the CJ125 chip and I'm thinking that the ecu may support both! Bosch LT4 is Bosch's own motorsports o2 controller, which is compatible with both 4.2 and 4.9 sensors, uses the CJ125 chip. Fingers crossed that the Infinity is the same way. This may be a win!
Conclusion: AEM needs to get their **** together
EngineLab:
CJ125 proposed circuit
- According to AEM, only Bosch 4.2 is supported
- According to EngineLab, the EL129 ECU was designed with Bosch 4.9 in mind
EngineLab:
Total Cats: 268
Total Cats: 268
An update!
I finally got the ECU. I made a small harness to connect the ECU to a 12V computer power supply so I can play with it outside of the garage.
I was able to flash AEM "generic" firmware on it, so that confirms that all the 7 series ECUs are basically the same, even if it is listed as application specific. I will of course confirm with the car running, but its a good sign.
Also was thinking about Infinity vs Megasquirt and one thing came to mind. With Infinity, you have full control over the fuel injection logic (using EngineLab firmware). So, you can use any sensors in the fuel calculations. That means you can have
Megasquirt only has basic voltage correction, and whatever else the dev team comes up with. Infinity with EngineLab firmware you can do whatever you want. Of course, if you just want plug & play its not for you.
- 2D table for injector deadtime vs voltage vs pressure (using battery voltage and pressure sensor as inputs)
- Linear table for injector flow vs fuel pressure (using fuel pressure sensor)
- Linear table for fuel density & fuel evaporation rate vs fuel temperature (using a fuel temperature from E85 sensor as input)
