Excessive oil burning, oil jets, stuck rings, acetone
Old 10-29-2016, 09:53 PM
Godless Commie's Avatar
Total Cats: 1,706
Originally Posted by Micztor
So when removing the oil jets, do you just let them be have the bolt hole open, or do are you supposed to screw a bolt in. Sorry for the silly question, I'm just trying to do it right. Thanks
You have to plug the holes with 10x1.25 10 mm plugs.
Otherwise you'll have a very short lived engine - no oil pressure, fried bearings, mayhem...
Godless Commie is offline
Old 10-29-2016, 10:46 PM
williams805's Avatar
Total Cats: 27
^ Afirmative
https://www.miataturbo.net/engine-pe...cussion-82895/
williams805 is offline
Old 11-22-2016, 04:23 PM
Total Cats: 1,706
Quick update:
Engine is out and disassembled, AND things look a bit grim at the moment.
Bearings are bad. #4 rod bearing has flaked.
The engine had a bad miss on #4 for a little while due to a collapsed valve seat.
Everything in the head has been replaced since, but the damage is done I guess.
#1 cylinder wall is scored.
Pistons have scratched skirts.
Crank needs polishing.
And yes, oil control rings were pretty much gummed.
Please stand by for massive photo dump...
Old 11-22-2016, 04:42 PM
Total Cats: 1,706
Rod bearings:
Old 11-22-2016, 04:45 PM
Total Cats: 1,706
Mains:
Old 11-22-2016, 04:47 PM
Total Cats: 1,706
Crank:
Old 11-22-2016, 04:50 PM
Total Cats: 1,706
Scored #1 cylinder wall:
(Photographing the cylinder wall is tricky, I tried a few different angles)
Old 11-22-2016, 04:52 PM
Total Cats: 1,900
Awww man :(
EO2K is offline
Total Cats: 1,706
Pistons:
(I cleaned one, then remembered I should have taken a photo.. Skirt scuffing can be seen, too)
Old 11-22-2016, 04:54 PM
Total Cats: 1,706
The block is getting custom sleeves.
There's no getting around those scratches.
I am not buying bigger pistons. I have 84 mm pistons already.
Old 11-22-2016, 05:10 PM
Total Cats: 1,706
Aaand, this is how you take your engine to the machine shop all the way across town, the right way...
500 ccs of smooth power...
Old 11-22-2016, 05:24 PM
Total Cats: 3,128
Wow, the bearings...
Did you have an oil pressure problem? Or starvation? Looks like debris in the oil as well.
What oil were you using?
sixshooter is online now
Old 11-22-2016, 05:28 PM
Total Cats: 1,706
I was using Mobil Super 3000 5w40
I'm thinking about using Shell Helix HX8 from now on.
And no, we do not have Rotella T6 over here.
Old 11-22-2016, 05:29 PM
Total Cats: 1,706
Also, I have a "shimmed" oil pump, and great pressure.
Oil change intervals are no more than 3-4K miles.
Old 11-22-2016, 05:41 PM
Yikes, why do you think this happened?
Old 11-22-2016, 05:44 PM
Total Cats: 1,706
Flaked bearing is self explanatory. (See related post)
The rest... I can't say.
Bad oil filter? I'm using a local brand.
Old 11-22-2016, 05:48 PM
Yeah, I saw how pitted and unhappy the bearings looked.
I guess this is a good reminder that I should swap out my oil and fuel filter over the winter...
Old 11-24-2016, 10:41 PM
Bronson M's Avatar
Total Cats: 218
I've heard....but not seen first hand that a flaked and pitted bearing like that is the result of detonation hammering them. The other bearings are more indicative of trash flowing through the engine (most likely from the flaked bearing) I would very closely inspect the #4 piston for signs of detonation. The collapsed valve seat is another indicator of that cylinder being hot from detonation. I see that you're running a coolant reroute, normally not running one is why you only see this issues like this on #4, the back cylinder runs hotter due to lack of flow and is the first to detonate when running on the ragged edge. In your case maybe it's a lower flowing injector or just dumb luck that it's #4 this showed up on.
Bronson M is offline
Old 11-25-2016, 05:50 PM
Total Cats: 1,706
Bad news keeps on coming.
I'll just leave these here..
It is being repaired as we speak.
Yes, it is possible to repair this.
And no, I can't find a block.
Old 11-25-2016, 10:10 PM
HHammerly's Avatar
Total Cats: 63
You want to find out how much it would be to import one? I have two block sitting here and you can have one for the shipping and import duty, land freight could not be that much...
HHammerly is offline
