Turbo downpipe
Total Cats: 196
doesnt look like a standard flange.
this piece is bolted to the turbo, unbolt it and see if the turbo has a standard T25 DP flange. also take a picture of the manifold that you have and the flange on the manifold and turbo.
Total Cats: 196
Thats not a T25. looks like some weird OEM turbo from another vehicle.
at a minimum you will need a custom manifold and downpipe to mate with this turbo, will be easier and cheaper to junk this and just get a standard T25 turbo and then you have a whole lot of different pre made manifolds and downpipes to choose from.
Total Cats: 3,133
If you REALLY want to use that turbo you need to replace the outlet adapter or find someone who will build a downpipe to match it. But you knew that already. I've never seen one like it and wouldn't waste time trying to match it.
If you posted some measurements I could help you identify it. That would require you taking it apart, though.
It honestly looks like a t3 40-50 trim from a turbo-diesel. If so, all you might need is a china v-band wastegate adapter. Dunno, though. Doesn't look like a t3 inlet flange to me, doesn't mean it's not still a pretty standard t3.
