Old 11-01-2016, 11:31 AM
  #8001
Epic. I've seen videos of some diesels running 100+psi.
Old 11-01-2016, 03:07 PM
  #8002
x_25's Avatar
Total Cats: 141
I got given one of the glowshift 60PSI guages. No idea what I am going to do with it sincd I never plan on running more than 12psi or so (if I can get the M45 to even make that much).
x_25 is offline
Old 11-01-2016, 04:12 PM
  #8003
Tradsies for my current gauge?
Old 11-01-2016, 11:34 PM
  #8004
yes, yessssssssssssssssssss I like where this is going
Old 11-01-2016, 11:42 PM
  #8005
Built a little fixture to align the tailshaft housing. This aligns the shift rod hole on the mill and lets me drill a hole for the extension on the back of the T5 perfectly.
Over 8000 posts. And its just starting to get good.
Old 11-02-2016, 01:51 AM
  #8006
patsmx5's Avatar
Total Cats: 519
How much are they for the 60 PSI version?
patsmx5 is offline
Old 11-02-2016, 10:20 AM
  #8007
x_25's Avatar
Total Cats: 141
Whatcha got? I already found the perfect VDO for my car. Vac/boost and goes to 15psi.
Looks like $47? I should check if mine works first. Lol.
x_25 is offline
Old 11-02-2016, 08:27 PM
  #8008
New springs showed up. ALLOFTHEREVS
the spare organic discs showed up. Going to go to a local place and see if they can put a new center in for me. Otherwise I will be calling everybody around the country until someone offers to put a new center in. Its just a few rivets.
Old 11-03-2016, 03:17 PM
  #8009
stefanst's Avatar
Total Cats: 74
There's a guy local in eastern PA who just re-used the original metal parts from an old clutch and made a whole new clutch for my buddy's '32 Buick. I'm sure he could put in a new center for you. LMK if you don't get anywhere and I'll ask him.
stefanst is offline
Old 11-03-2016, 03:20 PM
  #8010
Awesome. I'll ask around locally. The hardest part might be getting the new center for a t5 disc. I need to call comp clutch and see if they will sell me just the centers.
Otherwise I may have to buy a whole new set of discs for a t5 and pull the centers out.
Old 11-07-2016, 04:10 PM
  #8011
yank's Avatar
Total Cats: 32
Call Clutch Masters.
yank is offline
Old 11-07-2016, 04:39 PM
  #8012
I did. They asked if it was their disc and weren't interested in touching something that wasn't theirs.
They were interested in making custom discs though.
Old 11-07-2016, 07:34 PM
  #8013
Finally got a t25 flange in. Realllly happy with how the top runners turned out. Really clean and easy to weld. The collector is going to be a major bitch. Most of the welds will get little diamond braces ala turbotim. And I will have some sort of brace for the collector.
Old 11-08-2016, 12:00 AM
  #8014
Found this 95 block on the side of the road. Has oil feed port.
Should work well with the VVT head, and MBSP+Pan.
Old 11-08-2016, 01:08 AM
  #8015
afm
afm's Avatar
Total Cats: 508
Fell off the back of a truck?
afm is offline
Old 11-08-2016, 07:13 AM
  #8016
Was a joke. Got it from a friend.
Old 11-08-2016, 09:00 AM
  #8017
deezums's Avatar
Total Cats: 201
VVT Powah!
VVT oil pumps fit old NA cranks, right?
deezums is offline
Old 11-08-2016, 09:02 AM
  #8018
Afaik yes. Most annoying part is switching main caps so I can run the mbsp.
Old 11-08-2016, 09:08 AM
  #8019
deezums's Avatar
Total Cats: 201
If you can find a protege/escort block they come with the oil port and MBSP/caps. I think you need a 94+ protege BP though, earlier ones had a small crank bolt.
deezums is offline
Old 11-08-2016, 09:09 AM
  #8020
It's easier to just have the mains bored.
