ITT: We discuss T5 swaps and other information.
Old 10-10-2016, 10:33 PM
  #121
Total Cats: 104
where are you getting the longer one?
Leafy is offline
Old 10-10-2016, 10:39 PM
  #122
One of these:
And one of these (Thats a @hi_im_sean riding a motohorse):
Old 10-10-2016, 10:44 PM
  #123
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Disclaimer: I will not be riding the motohorse while operating the lathe.
hi_im_sean is offline
Old 10-10-2016, 10:45 PM
  #124
Old 10-11-2016, 11:39 AM
  #125
x_25's Avatar
Total Cats: 141
That's because the lathe goes on the motorhorse. Duh.
x_25 is offline
Old 10-27-2016, 11:07 PM
  #126
Here are some pictures.
These wont help with anything besides a 949 twin disc, but should help anyone else planning.
Waiting on some measurements from sean for the crank, but we might end up having to take a bit off of the end of the input shaft.
And maybe some custom discs, don't know yet.
(0.429")
Old 10-27-2016, 11:15 PM
  #127
I will draw it all up tomorrow.
I don't have mspaint at home.
Old 10-27-2016, 11:44 PM
  #128
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
I like dat green shift **** in the last pic.
Old 10-27-2016, 11:45 PM
  #129
Brb, rethreading for t5
Old 10-28-2016, 01:04 AM
  #130
What is the general consensus on input shaft spline engagement. With the twin disc and the t5 input shaft I would be missing about .12" out of like .75". But only on one disc.
Old 10-29-2016, 12:21 AM
  #131
Der_Idiot's Avatar
Total Cats: 28
Is that engaged or disengaged?
Der_Idiot is offline
Old 10-29-2016, 12:26 AM
  #132
Engaged. I remeasured. It's like .04 out of .35 or something. I still haven't drawn it all up.
worst case is I strip a disc or input shaft. Still have a second to limp home on.
Old 10-29-2016, 08:30 AM
  #133
Total Cats: 104
It'll probably be fine.
Leafy is offline
Old 11-01-2016, 08:12 PM
  #134
Built a little fixture to align the tailshaft housing. This aligns the shift rod hole on the mill and lets me drill a hole for the extension on the back of the T5 perfectly.
Old 11-14-2016, 01:43 PM
  #135
Just found a t5 flange drawing on an alfa site.
Another T5 Conversion Thread - Alfa Romeo Bulletin Board & Forums
And here is my version with the holes for the alfa bellhousing removed.
Printed one out. Going to check it on the trans tonight.
Going to rough cut a miata bellhousing to make sure I don't need to add any material anywhere and then get this waterjetted.
Old 11-15-2016, 09:22 PM
  #136
REDBEN's Avatar
Have you looked in to use a NA Miata Automatic Bellhousing? Could make adapting easier...
REDBEN is offline
Old 11-15-2016, 09:28 PM
  #137
I need the clutch hydraulics
Old 11-15-2016, 09:30 PM
  #138
REDBEN's Avatar
Ah I see, I had intend to use a hydro release bearing, but it's a short enough Bellhousing.
REDBEN is offline
Old 11-15-2016, 09:59 PM
  #139
Hydro release bearing costs more than the trans I bought.
Good solution tho.
Old 11-16-2016, 09:15 PM
  #140
Total Cats: 104
If you're turning it down I'll sell you a quartermaster hydro release bearing for $150. $250 regular price, brand new.
Leafy is offline
