In Soviet Russia car build YOU!
Old 10-14-2016, 11:15 AM
  #2041
psyber_0ptix's Avatar
Hell yea
psyber_0ptix is offline
Old 10-14-2016, 11:16 AM
  #2042
How do the vvt wires fit in the 99 head? Decent?
Old 10-14-2016, 11:31 AM
  #2043
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Well I was told to send VVt wires. Thats not a VVT head....
#1 looks tight because it should be bent 90 degrees and snapped into the head boot, and then the coil boot points down.
hi_im_sean is offline
Old 10-14-2016, 11:39 AM
  #2044
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
This is your exact wire set mocked up on a 99 VC.
And ill be glad to exchange for the 90-00 wires if you want to send them back.
  #2045
Like this
  #2046
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Dat timing aidan lol
Old 10-14-2016, 11:42 AM
  #2047
Total Cats: 1,900
Wait, premade wires with bracket? Where do I sign up?
EO2K is offline
Old 10-14-2016, 11:52 AM
  #2048
Welcome back! we missed ewe
https://www.miataturbo.net/miata-par...-thread-89172/
Old 10-14-2016, 01:21 PM
  #2049
soviet's Avatar
Total Cats: 268
Oh, so I'm an idiot and routed the wires with my butt instead of my hands. Will fix.
And I have a VVT head, its just not attached to a block
soviet is offline
Old 10-14-2016, 02:21 PM
  #2050
Chiburbian's Avatar
Total Cats: 202
If you were referring to the SADfab bracket... no excuses...
(not mine)
Chiburbian is offline
Old 10-19-2016, 02:14 PM
  #2051
soviet's Avatar
Total Cats: 268
Got AN bungs welded on mah radiator. Its so pretty.
Made progress on the fusebox bracket. Using 1.6mm aluminium. Rough cut of the hole for fusebox mount. Still gotta finish the cuts and then bend the bracket.
soviet is offline
Old 10-19-2016, 03:39 PM
  #2052
Is that a -16 AN?
Old 10-19-2016, 04:38 PM
  #2053
soviet's Avatar
Total Cats: 268
Is that a -16 AN?
Yes. A while ago I got in on a group by for CNC -16 AN coolant spacer/inlet/outlet so that determined the hose size.
It should be sufficient.
https://www.miataturbo.net/miata-par...ittings-76320/
soviet is offline
Old 10-21-2016, 07:05 PM
  #2054
soviet's Avatar
Total Cats: 268
FInished the fuse box bracket, looks better than expected.
Now gotta actually finish the wiring.
soviet is offline
Old 10-21-2016, 10:54 PM
  #2055
pusha's Avatar
Total Cats: -29
when can I expect my completed wiring harness?
pusha is offline
Old 10-23-2016, 01:08 PM
  #2056
Stealth97's Avatar
Total Cats: 66
Holy cow that looks awesome
Stealth97 is offline
Old 10-23-2016, 01:14 PM
  #2057
Take a picture of your CAD design with a ruler next to it. Would make it easy for others to reproduce.
Old 11-25-2016, 08:18 AM
  #2058
soviet's Avatar
Total Cats: 268
Wiring, wiring, wiring.
Terminated the front wiring harness (lights, fan, etc) and wired it to the fusebox.
I'm using Molex MX150 connectors for most of the things, and Metri-Pack 280 for the high-amp stuff.
Conviniently, the fuse box (Bussmann 15400) also uses Metri-Pack 280 terminals, saving me on stuff I need to buy.
Finally, as some of you have seen I sold my MS3 + MS3X. I will replace it with something new. The new ECU will be at least an MS3Pro and maybe I can swing an AEM Infinity.
Some of the things that attract me to AEM Infinity vs MS3Pro
- built-in O2 controller. So I can get rid of the O2 controller and sell it
- does not need any hoopla to hook up a turbo speed sensor. So I can get rid of the turbo speed converter box and sell it
- has a lot of failsafes
Some of the things that MS3 Pro has over Infinity
- I know Megasquirt and TunerStudio pretty well
- $300 cheaper ECU
- $40-70 cheaper plug and pin kit (it adds up)
soviet is offline
Old 11-25-2016, 11:09 AM
  #2059
Total Cats: 1,685
- $300 cheaper ECU
What failsafes does the AEM have that MS3 does not? I am assuming you just need the JBPerf board for the turbo speed sensor correct? Don't you already have it and it is wired up? I also don't understand the need to g oto the built in O2 controller. You sell your wideband for $100, then still need to go buy a new O2 sensor for $50 anyways. So does not seem like that big of an issue.
shuiend is offline
Old 11-25-2016, 11:15 AM
  #2060
Turbo speed sensor has an external box that converts from the speed sensor input to an analog signal.
I might be interested if you are selling it
Quick Reply: In Soviet Russia car build YOU!
