TURBO AUTO NB
#43
If you have ABS on the car you can do what we did here:
https://www.miataturbo.net/ecus-tuni...-sensor-85749/
#47
My impression of the auto is its amazing alot smoother and more driveable than expected actually easier to drive than the manual other than it wanting to blow the tyres off
the auto place is in melbourne australia they specilize in jatco's because they are in a large 6 cyl turbo car here in oz
the issues we hit
Happy to speak to the guys here if you need help i see you have a 99 aisin box which i got warned away from to hard to control as its all electronic and no available upgraded aftermarket parts
other than that all good hardest parts finding the jatco frame rail and flex plate
the issues we hit
- converters very small had to machine up a custom balloon plate section
- rear seal inside miata extension housing only just fits
- input shaft depth with converter
- drop box for shifter very tight
- tailshaft modified to suit larger auto output shaft
- billet input and output shaft
- fully manualised valve body
- stronger bands and higher line pressures
- retained over drive
- waiting on a higher volume cast pan
- b&m compatable shifter brackets
#50
Small frame turbo has no issue building boost off the line the reason i opted out the car gets driven on the street alot and i wouldnt be able to help myself
later if i change turbo's its easily added
Ill try and gets some video's up its been raining for almost a solid two weeks up here
#51
Good excuse for delays with the mx5
Been a bit side tracked fixing up my new daily picked it up too cheap to say no needed a bit of love its a jzx100 a toyota chaser amazing cars fairly rare here in OZ
i have some semi's for the mx5 so i might be putting them on this week and my remote bluetooth unit for the audio is due to arrive aswell this week so stuff is still happening
#52
Got some 225/50/15's i had fitted today they are perfect i also picked up some stock rear springs and ordered some stock height sports rear shocks so i can try out and see what hooks up best at the drags
i havent made any video's cause i have let my registration lapse i will have that fixed in the next few weeks
