Shuiend blows motor #5; Naturally Aspirated Glory Incoming
Old 09-06-2016, 01:07 PM
  #1901
Total Cats: 558
Originally Posted by shuiend
So I had wired the oil pressure sensor for the MS to the wrong wire on my TPS plug. Switched it to the correct 5v wire and I am building 18-20psi just cranking the motor with no spark plugs or injectors hooked up. So I am getting pressure. I think my stock sensor that goes to the gauge cluster is finally done. I can at least watch oil pressure in TS while I am breaking in the motor.
Glad to hear that no harm was done.
sonofthehill is offline
Old 09-06-2016, 01:47 PM
  #1902
Total Cats: 1,684
Car is idling. We are warming it up now and getting idle and tpsdot settings decent. Should be changing oil shortly then going to break in the motor. Oil pressure gauge in cluster is not working still after swapping to a different sender, but MS is reading it fine so will worry about that one later.
shuiend is offline
  #1903
booooost.
Old 09-06-2016, 03:42 PM
  #1904
Reverant's Avatar
Total Cats: 358
Originally Posted by soviet
Can you post your settings for the 36-2 trigger wheel?
I occasionally wonder what it would take to modify the FM 36-2 code to run with Supermiata 36-2 damper.
Wait, don't they have the same phasing?
Reverant is offline
Old 09-06-2016, 03:44 PM
  #1905
Originally Posted by aidandj
Nothing. It is plug and play.
Yes. They are the same. Just install it and go.
Old 09-06-2016, 04:00 PM
  #1906
Total Cats: 1,684
During engine braking for brake in it pulled down to 9kpa. I figure that is pretty good. The 3.63 gears make first and second gears actually usable with the 6 speed. It felt pretty strong naturally aspirated. Need to fix a few things before I take it back out and get into boost. I will work on that later this week. Big thanks to Efini~FC3S for hooking me up with a awesome price on a built motor. I am so ******* happy to have my car driving again.
shuiend is offline
Old 09-06-2016, 04:07 PM
  #1907
psyber_0ptix's Avatar
yay!
psyber_0ptix is offline
Old 09-06-2016, 06:05 PM
  #1908
soviet's Avatar
Total Cats: 268
soviet is offline
Old 09-06-2016, 06:06 PM
  #1909
Yep. It happened without any warning. We needed a supermiata damper for turbofan's car. And when i looked at the options last year it said 36-2. Never saw a change announcement. We installed it, switched to 36-2 triggering and away we went.
Old 09-06-2016, 07:11 PM
  #1910
Total Cats: 1,684
At first we were messing toothed wheel and trying to figure out angles, because we missed the right option. I emailed 949 and asked and they said "Miata 36-2". We looked at the list again and switched to it. Car started up damn near perfectly on the first try. It starts far better then any of my other cars using the stock 4 tooth trigger wheel. I will post a screen shot tomorrow of the settings I am using.
shuiend is offline
Old 09-06-2016, 07:32 PM
  #1911
Total Cats: 1,899
IIRC back when I bought my 949 damper (preorder group buy, first production run) there was no code for the MS, or at least that's what everyone told me at the time. This makes me want to change to the 36-2.
EO2K is offline
  #1912
It used to be a 36-1. Which there wasn't code for. Like mentioned above it got switched to a 36-2 somewhere along the line.
Old 09-06-2016, 07:42 PM
  #1913
Total Cats: 1,899
Bitchin. I'll have to look into this the next time the motor is out.
EO2K is offline
Old 09-07-2016, 08:32 AM
  #1914
Total Cats: 1,684
Here are my Ignition Settings. Most people won't have cam input on JS10, so don't follow that.
shuiend is offline
Old 09-07-2016, 08:49 AM
  #1915
Total Cats: 4,102
Most should use MS3X cam, and flipped polarity.
Braineack is offline
Old 09-07-2016, 06:06 PM
  #1916
Total Cats: 4,102
Old 09-07-2016, 06:08 PM
  #1917
Total Cats: 4,102
Old 09-07-2016, 08:10 PM
  #1918
Total Cats: 1,684
This is my favorite.
Now onto something interesting I found tonight. I forgot a ground somewhere or messed something up wiring wise. Watch what happens when I turn my lights on and off.
shuiend is offline
Old 09-07-2016, 08:42 PM
  #1919
Total Cats: 4,102
might explain the OPG not working.. lol
Old 09-07-2016, 11:15 PM
  #1920
that intake manifold
Quick Reply: Shuiend blows motor #5; Naturally Aspirated Glory Incoming
