gt2560r external wastegate. HOW TO WASTE MONEY FOR SPOOL
Old 08-12-2016, 03:56 PM
LownSlow616's Avatar
Total Cats: -12
I think the gusset is a great idea. However, I cant TIG worth a ****. And that might void my warranty. IF it ever cracks, gleasemanufacturing will fix it. And he would probably add a gusset as well.
As far as im concerned, this is a gleaseman manifold. Fab9 provided the worst customer service that I have ever received.
LownSlow616 is offline
Old 08-19-2016, 10:34 AM
Total Cats: -12
turbo on and clocked
aerocatch latches and GV lip installed
wrapped screamer pipe and dp. this is the completed engine bay
dyno sheet coming next week
Old 08-19-2016, 10:38 AM
Total Cats: -12
This is how the hood looks from the outside. Screamer pipe isnt too noticeable...until WOT
Attached Thumbnails gt2560r external wastegate. HOW TO WASTE MONEY FOR SPOOL-img_20160717_141827.jpg
Old 08-19-2016, 10:45 AM
I like it
Old 08-19-2016, 10:55 AM
Total Cats: -12
thanks! It will be hitting a dyno (mustang) next week. Hopefully the operator knows what hes doing. Im at 13psi and FMs base ignition map. Any idea what it will make?
Old 08-19-2016, 10:59 AM
built engine? pump gas?
Old 08-19-2016, 11:10 AM
Total Cats: -12
Stock 43k mile 1999 engine. 93 octane
Old 08-19-2016, 11:15 AM
Old 08-19-2016, 11:57 AM
Girz0r's Avatar
Total Cats: 323
Props awarded , this is coming along nicely
Girz0r is offline
Old 08-19-2016, 12:19 PM
yossi126's Avatar
Total Cats: -14
Great job Reed!
Looking forward to dyno.
yossi126 is offline
Old 08-19-2016, 12:28 PM
Total Cats: -12
220-250
even on a mustang dyno and this wimpy ignition table?
Old 08-19-2016, 12:31 PM
with that table on a mustang, probably more like 170-190
Old 08-19-2016, 12:58 PM
Total Cats: -12
I know I can use waaay more timing. I just don't know where to increase it and where to not. And jeremy at FM is on vacation. Should I just add say 4 degrees in every cell above 100kpa?
Old 08-19-2016, 12:59 PM
Depends, how soon do you want to vent the block?
Old 08-19-2016, 01:28 PM
Total Cats: -12
Not yet. Mid November wouldn't bum me out that much though. Maybe ill ask jeremy for a more aggressive spark map and ill see if the hydra detects any knock. For the amount of money i have into this, I am going to feel really silly if i dont see over 200 on a mustang dyno
Old 08-19-2016, 01:39 PM
afm
afm's Avatar
Total Cats: 508
I take it you don't live in CA
How much does the pipe tip move at WOT in a low gear?
afm is offline
Old 08-19-2016, 02:12 PM
Total Cats: -12
I live in west MI. 93 octane
not much. the engine mounts are stock too. It moves the most on start up. the hole is 2 1/8" and the pipe is 1.5" so it has plenty of room
Old 08-19-2016, 02:14 PM
there's a joke in there somewhere
Old 08-19-2016, 02:16 PM
huesmann's Avatar
Total Cats: -15
Needs one of these!
huesmann is offline
Old 08-20-2016, 10:58 AM
borka's Avatar
Total Cats: 196
I predict about 220HP at 13PSI on this timing map. my setup made 211HP 201TQ on a very similar timing map at 11-12PSI.
a little off topic. I love how uncluttered your engine bay is, how did you get rid of all the clutter on the left hand side of the engine, there are a million vacum hoses and sensors there on my 99 and nothing on yours?
borka is offline
Quick Reply: gt2560r external wastegate. HOW TO WASTE MONEY FOR SPOOL
