Old 08-10-2016, 06:34 PM
  #7221
Total Cats: 1,900
Dang, I leave for a week and this happens?
I'll message you on hangouts sometime this afternoon, I have offline commentary
EO2K is offline
Old 08-10-2016, 06:37 PM
  #7222
I know right? I'm as surprised as you are.
Old 08-10-2016, 07:04 PM
  #7223
Oh i forgot. These showed up too
  #7224
@Leafy
What about this? Chevy T5 Shift Lever Striker New Bushing Kit WC or NWC 1351098005 8134054 | eBay
Old 08-10-2016, 07:39 PM
  #7225
patsmx5's Avatar
Total Cats: 519
Well things are changing here! Very nice!
patsmx5 is offline
Old 08-10-2016, 07:51 PM
  #7226
patsmx5's Avatar
Total Cats: 519
If you go all baller parts build on us, you're not going to settle on 250-300whp are ya?
patsmx5 is offline
Old 08-10-2016, 07:57 PM
  #7227
If I do a rods only build I wont push past 300.
If the stars align and I get pistons then i'll be trying to match soviets numbers.
Old 08-10-2016, 07:59 PM
  #7228
patsmx5's Avatar
Total Cats: 519
Do rods/pistons since you're all baller now. No point in building a baller (but limited by one thing) build.
patsmx5 is offline
Old 08-10-2016, 08:03 PM
  #7229
I can do a rods only rebuild for like $500.
I haven't been able to price out a full engine build for less than like $2500.
I have a wedding, and a house to save for. And hailey will hopefully be starting school again in January.
And while I'm not here buying parts paycheck to paycheck, dropping an extra $2k is not a smart move.
I mean thats like 10% of my downpayment goal.
Old 08-10-2016, 08:27 PM
  #7230
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
I for one approve of your new tittle and where the car is headed. I always knew you hated the track and love the cones.
hi_im_sean is offline
Old 08-10-2016, 08:29 PM
  #7231
Old 08-10-2016, 09:23 PM
  #7232
Old 08-10-2016, 09:24 PM
  #7233
bout **** my pants at 1:00
Old 08-10-2016, 09:27 PM
  #7234
patsmx5's Avatar
Total Cats: 519
I understand the budgeting. If it needs to wait then so be it.
Instead of a rods only build, what about a rods only, plus:
forged pistons (~500)
bore/hone at a shop (~200)
and that's it.
There is no way that will add 2,000 dollars more than a 500 dollar rods only motor.
Just don't move the goal post and try to upgrade/replace 20 things "while you're in there".
patsmx5 is offline
Old 08-10-2016, 09:29 PM
  #7235
Because if i'm gonna build a motor that can handle the power that forged pistons are necessary for then I want all the other "while you're in there" stuff.
I guess bare minimum for a build that included pistons for me would be:
pistons (~500)
race bearings
boundary pump
main studs (because i already bought them) + line bore
head studs.
It all starts to add up. I need to do more budgeting and see where stuff ends up.
Old 08-10-2016, 09:52 PM
  #7236
yossi126's Avatar
Total Cats: -14
Stick to rods. Life is more important.
yossi126 is offline
Old 08-10-2016, 09:53 PM
  #7237
I have 2 blocks. And its not that hard to put together a big build later down the road.
I bought the turbo right now because it is something that I can easily sell if I need the money.
An engine build is more just throwing money away.
Old 08-10-2016, 10:02 PM
  #7238
Also, i've ridden in eds 300hp miata. And you need some serious tires above that power level. I feel like you can scrape by on the street with 225's. But barely.
Goal will be a safe ~300hp. I think with good tuning the stock pistons should manage that.
It also will be well within the efficiency range of the turbo, so there shouldn't be a lot of heat.
Also I still struggle on the track with 160hp. So I'm planning on a dual port turbosmart wastegate actuator with a 3 or 5psi spring.
Old 08-10-2016, 10:18 PM
  #7239
Total Cats: 858
You don't need the line bore to use the ARP studs.
340 at the wheels is fine on the street with 15x9s and 225 Rivals.
You're seriously proposing to open up a motor to replace rods and re-use the bearings that were already in it???
codrus is offline
Old 08-10-2016, 10:40 PM
  #7240
afm
afm's Avatar
Total Cats: 508
Hot damn $108 per tire is a great deal.
afm is offline
