miataturbo.net-like debauchery thread (about the ND or something)
Old 07-22-2016, 07:19 PM
  #2701
13 compression on a modern engine aint the same 13 compression that we're used to working with on a prehistoric BP.
while I don't think mazda "beefed" up the trans for more power, I do think they're well aware that most of these cars will be driven hard through twisties and track, so I don't think it's a "glass box".
the fuel system question is a good one
Old 07-23-2016, 08:49 PM
  #2702
Ziggo's Avatar
It's 13:1 in static compression, but I bet the dynamic compression is quite a bit different with the VVT backed off and that intake valve closing well after BDC
Ziggo is offline
Old 07-23-2016, 09:11 PM
  #2703
If Mazda went as far with weight reduction on the gearbox as they did on the weight reductions on the rest of the chassis I could see it being a glass box. For the most part stronger trans=bigger internals=heavier box.
Who knows though. Time will tell.
Old 07-23-2016, 09:47 PM
  #2704
correct
not a problem when you can bleed it off
Old 07-23-2016, 09:56 PM
  #2705
Total Cats: 2,387
Most of the N/A power in tuning the SAG is by simply retarding the exhaust cam and watching knock. There are other tricks but the exhaust cam is the low hanging fruit. I call it de-atkinsoning.
.31 SNR
emilio700 is offline
Old 07-24-2016, 01:21 PM
  #2706
Total Cats: 104
Originally Posted by deezums
There's really no way you could answer that question definitively yet....
I still think the ND carries a glassbox. The Fiat didn't get that transmission for a reason.
And from all accounts the fiat uses the NC tranny, so thats sounds like a pretty easy swap for someone doing a turbo setup.
Leafy is offline
Old 07-24-2016, 09:26 PM
  #2707
ThePass's Avatar
Total Cats: 1,216
How exactly is an NC box in the Fiat, a completely different engine with no similarity to the 2.0 skyactive, of any help to someone with an ND?
Also, the bellhousing is not the same as the NC, so Fiat guys won't be able to source NC transmissions as replacements, even if it is the same internally.
Ryan Passey
ThePass is offline
Old 07-25-2016, 06:32 AM
  #2708
Chilicharger665's Avatar
Total Cats: 57
Well, I am up to 1500 miles now and this car is just fantastic. However, the suspension is hilariously soft and I had to take it easy on the back roads of the hill country between Austin and San Antonio the past few days. You can feel the weight transfer from when you do absolutely anything. Accelerate and the things squats hard, hit a bump in mid corner and the whole car heaves sideways. I can't wait to get some real suspension on it. I also really need to get an LSD, because wheel spin from moderate cornering is quite annoying.
The dealer continues to be unresponsive about my top issue.
Chilicharger665 is offline
Old 07-25-2016, 09:27 AM
  #2709
Did you know that salmon have a more keen sense of smell than that of a dog or a bear?
Dunning Kruger Affect is offline
Old 07-25-2016, 12:00 PM
  #2710
ThePass's Avatar
Total Cats: 1,216
Ryan Passey
ThePass is offline
Old 07-25-2016, 09:06 PM
  #2711
Total Cats: 104
It means that the normal NC box from an actual NC will have the shifter in the right spot when you bolt it to the back of the skyactive.
Leafy is offline
Old 07-25-2016, 09:12 PM
  #2712
doward's Avatar
Total Cats: 762
that assumes the Skyactive and the MultiAir share identical mounting locations in the bay and are the same length.
We we already know that they have different bell housing patterns, so you'll need an adapter to put an NC trans on an ND motor.
doward is offline
Old 07-25-2016, 10:01 PM
  #2713
ThePass's Avatar
Total Cats: 1,216
Making more assumptions than I have time to count...
Ryan Passey
ThePass is offline
Old 07-27-2016, 11:22 AM
  #2714
Total Cats: 2,387
Discovered something interesting and quite counter intuitive on the dyno yesterday. When doing OEM baselines we always run an OEM like tire. In the case of the ND we assumed the huge RE71R would be costing it 2-3whp. Not so. Both sets inflated to 30psi, same coolant and IAT temps at start of pull then SAE corrected. Did multiple runs in each config and the results were the same. Picked to representative pulls to display. I'm sure there is a significant aero drag components and then tire scrub when cornering but straight line rolling resistance appears to be a wash. Weird.
BTW, you can use 140whp as Dynojet SAE corrected power for the ND, heat soaked. We could cheat the number a bit on a cold engine but 140whp is real world. Goodwins dyno shows 137~138 for the baseline I think so all their numbers are conservative by that amount. Got the Goodwin header on last night. SOTP feels like at least 10whp on the stock map. Will post dyno's in a day or so.
.31 SNR
Old 07-27-2016, 11:34 AM
  #2715
Ziggo's Avatar
Additional rolling resistance of the wider, softer compound tire being offset by stiffer sidewalls and higher relative pressure?
Edit- that came out wrong. I should have said that at equal pressures both tires actually make the same area of contact, might even be smaller for the 245 with the stiffer sidewalls.
Ziggo is offline
Old 07-27-2016, 01:40 PM
  #2716
Blackbird's Avatar
Total Cats: 412
Default Fire Truck Red ND RZ over Jet Black
Finally got around to edit and upload the gallery for the beautiful Jet Black Club that we installed our ND RZ in.
The Fire Truck Red powder coat is pretty much a dead match to the Brembo calipers, so for those who are looking to pick up a bit of color, consider this a great looking $80 option on Brembo equipped cars :thumbs:
Took this pic for those who asked about the way the side cubbies behind the seats look like post installation -
I'll upload pics of the covers in a separate post.
Enjoy!
Blackbird is offline
Old 07-27-2016, 01:41 PM
  #2717
psyber_0ptix's Avatar
no worky!
psyber_0ptix is offline
Old 07-27-2016, 01:42 PM
  #2718
Blackbird's Avatar
Total Cats: 412
Default Cosmetic covers for ND RZ installation are now available!
The covers for the ND RZ installation are now available and you can order them directly from us, just shoot me an email or call us at (818)339-3884.
They are priced at $95 plus shipping, with no charge on shipping if they are ordered with the bar.
The covers are supplied with the sticky back Velcro, ready to install in a matter of minutes -
The production covers were further optimized from the ones shown previously by cleaning up the design even further to create a more seamless look.
Installation is nearly identical other than changing the location of one small piece of Velcro on each side (moved from the top to the back of the panel).
We've been working hard to finish off the looks of the ND RZ installation to make it as factory-looking as possible.
Next on our to-do list is a ND RZ specific clear wind deflector which will double up as a great way to make the cheese grater looking OEM deflector go away
Stay tuned!
Old 07-27-2016, 01:50 PM
  #2719
Blackbird's Avatar
Total Cats: 412
no worky!
Yes, sorry... I forgot for a moment that MT.net insists on uploading images that already have a URL once AGAIN instead of just reading [IMG] like any normal forum
Old 07-27-2016, 01:51 PM
  #2720
Damn I love these bars. Can't wait for you to take my money whenever you have the time lol.
Quick Reply: miataturbo.net-like debauchery thread (about the ND or something)
