No Lauch Control
Check the upper clutch switch. There's a little rubber plug in the clutch pedal that the switch hits. After 20 years the little rubber plug has gotten hard, cracked, and fallen out so the switch is no longer engaging. Buy a plug from a dealer or just tape a penny over the hole. But yeah, you don't need it.
the video is on YouTube im sure if you just searched " Miata launch control setup" it will be the first or second video>
thumpetto007
05-26-2016 08:17 PM
