ID1000's -> fuel rail fittment
Old 05-31-2016, 10:13 PM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
Default ID1000's -> fuel rail fittment
I've seen it mentioned once or twice before but I can't find the threads now. I've found that the length of the Bosch EV14 style injectors (I'm using XSpurt) are slightly longer than the stock injectors so that I have to space the fuel rail upwards around 4-5mm to get it to fit right. In doing so the injector extension tops get skewed sideways a bit and the injectors don't sit square to the head. It doesn't leak at all but is this a common fitment problem with any EV14 injector?
Madjak is offline
Old 05-31-2016, 10:15 PM
xspurt whatever is not ID which is Injector Dynamics.
and no, it is absolutely not the same thing.
Injector dynamics uses the proper bosch cores with the appropriate spacers so all of them fit 100% no modification or anything required.
Old 05-31-2016, 10:29 PM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
Ahh ok... that's why I can't find the info I was searching for. There must be several EV14 based injectors though that have the issue.
So is the problem just with the spacers? Maybe I should pick up some of the ID ones.
Madjak is offline
Old 05-31-2016, 10:33 PM
if you have an opportunity to run ID, do it. they are the best.
but otherwise yeah, there are several different sizes of bosch cores and some companies really suck at properly matching the extension hats to them, much less actually flow matching the 4 and just overall keeping quality control/precision top priority.
hence the price difference
Old 05-31-2016, 11:21 PM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
thanks heaps... great info. I'll measure my injectors at some point and report back to see if it's just the spacer or the body of the injector itself. ID release all their dimensions for their injectors so it will be easy to compare.
Madjak is offline
Old 05-31-2016, 11:40 PM
nitrodann's Avatar
Double post
nitrodann is offline
Old 05-31-2016, 11:41 PM
nitrodann's Avatar
I have no idea why in australia its normal to conflate any 1000cc injector with ids.
I have asked for ID by name from reputable efi shops only to be handed generic chinese rubbish, and for the guy to reply 'its the same thing mate'.
No its ******* not.
It isn't windex, its not kleenex, it matters and chinese junk is not interchangeable with ID.
Old 06-01-2016, 12:01 AM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
The title of the thread was probably incorrect but I could have sworn that the posts on injector lengths not fitting related to the ID injectors.
I am a culprit of thinking ID's used the same base Bosch body as other EV14 based brands, I was aware that each company applied their own modifications / QC etc to the injectors but I thought the base body and spacer would be identical across all EV14 based injectors. I didn't expect there to be different base core sizing and difference spacers, though looking at pics of the ID injectors they definitely have different shaped spacers.
18PSI when you refer to 'proper Bosch cores' are you inferring that some non ID injectors aren't legit Bosch parts?
Madjak is offline
Old 06-01-2016, 12:14 AM
Yes absolutely. There's SO many poorly made replicas that ID actually has a whole section about it on their site. (check it out)
Some companies go as far as putting a "injector dynamics" sticker on their replica. it's really bad.
I only buy from trusted sources for this very reason.
But even the ones that do use genuine bosch parts - the actual core is just part of the equation. The real magic is how they're modified and how they're matched and all that. So really, you could buy "genuine" bosch and still have junk.
Old 06-01-2016, 12:23 AM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
Here is the dimensions for the Miata model of ID: 64.7mm overall length o-ring to o-ring (ID)
The Xspurts are meant to be 65mm according to the spec page: https://www.injectorsonline.com/au/f...ngth-11mm.html
Unless there is something wrong I can't see where my 5mm difference is coming from. I'll have a good look tonight and see if I can find where the extra length is coming from.
Attached Thumbnails ID1000's -> fuel rail fittment-80-id1000_60_111_e8f7b1524b133743729981074d33809fb7d21f25.png
Madjak is offline
Old 06-01-2016, 04:19 AM
nitrodann's Avatar
I literally grill my TRUSTED SOURCE of injectors to make sure that he is grilling his trusted source, every time.
Its that bad.
Dann
Old 06-01-2016, 04:27 AM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
I know what you mean Dann... is it an Aussie thing or more globally? If you have a look at the first few google links for Xspurt, you'll see them referred to as 'basically ID1000's' in every thread. This is by the guy selling them locally on the Nissan forums. So anyone reading those threads or searching for injectors on *.au websites sees those pages.
I'm not bagging the Xspurts because they work well in my car but it's hard when buying EV14's to trawl through the misinformation to get good info about the differences.
Madjak is offline
Old 06-01-2016, 04:41 AM
nitrodann's Avatar
When I want to pass emissions tomorrow, and give the guy a 350whp car he can teach his 16 year old daughter to drive in, I need the real things, which behave exactly as advertised.
Old 06-01-2016, 09:36 AM
Saying xspurts are basically ID1000s is like saying your custom built race car is basically a stock miata. Yes they are both Miatas, but are still very different cars.
Old 06-06-2016, 10:31 AM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
I used larger rubbers on the head end of the injectors. They came off my previous injectors and are a little thicker than the o rings that came with the injectors. I prefer them as they seat better against the head.
So to fix the extra few mm of height on the Xspurts I've made a billet fuel rail that places the rail correctly without addition packers. I test fitted it on a spare head.
I like having a CNC machine! I've been meaning on making a custom rail to tidy up the engine bay and place the fuel lines either side of my Honda intake manifold.
Attached Thumbnails ID1000's -> fuel rail fittment-80-20160606_214046_zpsjkdqty14_c2ed2fe879a4ab77262e172da53e153693b6730a.jpg   ID1000's -> fuel rail fittment-80-20160606_213923_zpsseuvqwtc_74947844be384713a43251b3133cff839a13aaca.jpg
Madjak is offline
Old 06-06-2016, 10:35 AM
Wow, that's pretty cool being able to make your own fuel rail.
Old 06-06-2016, 10:37 AM
Girz0r's Avatar
Total Cats: 324
That's pretty awsome Nice Work!
Girz0r is offline
Old 06-06-2016, 11:03 AM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
Yeah... I enjoy making things by hand, but it's even better to be able to model it in 3D, hit print and then watch your part be whittled out of the billet. This fuel rail took around 5 hours of milling all up. I picked up the ally on Friday after making this thread, started it last night, completed one side and then flipped it over and ran the other side this morning.
Tonight I used the tool holder on the lathe to mount the fuel rail and bored out the center with a 175mm drill held in the chuck, drilling in from each end. Luckily they met nicely in the middle. There was a good chance it wouldnt drill straight.
I was toying with the idea of making some custom drop spindles. I would probably only drop the ride height around 20mm so that I can run my current suspension. Maybe run different bearings like the Keisler ones. The hard part would be measuring and placing all the geometry correctly. It would probably take a few prototypes to get it right so I'm not sure its worth it.
Madjak is offline
Old 06-06-2016, 05:14 PM
All-round "Good Guy"
Lokiel's Avatar
Total Cats: 252
Its that bad.
Dann
I bought my ID725s and ID1000s interstate from Adaptronic despite knowing local sources of these for this reason.
The last thing you want when trying to tune a car yourself is questionable injectors or unknown dead times.
Lokiel is offline
Old 06-06-2016, 11:36 PM
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
What are everyone's thoughts on running fuel rails without dampers?
I haven't had one for 2 years an haven't seen any issues, though my engine doesn't idle well at the bet of times. My understanding is that most aftermarket FPR's have some damping anyway although it's not located at the fuel rail. Anyone have some more info on it?
Madjak is offline
Quick Reply: ID1000's -> fuel rail fittment
