DIYPNP MS2Extra - Stalling due to Sync Loss Reason 39, CAS signal
Old 05-29-2016, 09:00 AM
JustinOMGWTF's Avatar
Default DIYPNP MS2Extra - Stalling due to Sync Loss Reason 39, CAS signal
Nope.
JustinOMGWTF is offline
Old 05-29-2016, 07:44 PM
Nope.
Old 05-30-2016, 03:26 AM
adryargument's Avatar
Total Cats: -20
Sync loss 39's in my car were bad coils and a bad CAS. Both were causing Sync 39's and was a bitch to figure out.
No idea if your using COPS or not.
adryargument is offline
Old 05-30-2016, 05:48 AM
Nope.
Old 05-30-2016, 08:58 AM
hector's Avatar
Total Cats: 168
Are the pull-ups wired to 12V or 5V? Try opposite of whatever you have and see if it makes a difference. I have MS3 and an 01 engine but I would get sync losses with my pull ups wired to 12V and they completely disappeared when I put them to 5v.
I would have guessed this to be a ground problem but you said you covered that. And on the voltage spikes, while they may be present I don't know that it would affect the ecu. It should have a voltage regulator that can handle that or the ecu would be toast in no time.
Edit: and you can try different resistors for the pull ups instead of just the 1K ohm recommended. I know it's a proven installation but not every car is going to be identical for one reason or another.
hector is offline
Old 05-30-2016, 10:58 AM
Nope.
Old 06-01-2016, 09:15 PM
Nope.
Old 05-18-2017, 10:16 PM
Nope.
Old 07-22-2017, 12:41 PM
vitorjorge's Avatar
Originally Posted by JustinOMGWTF
Back to the trouble-shooting drawing board.
Any luck
I have a similar problem but only became more notorius when i turn on boost control.
check the video from second 50 to 60 the compose log is like yours...
https://www.miataturbo.net/megasquir...-signal-92626/
vitorjorge is offline
Old 07-22-2017, 01:52 PM
Total Cats: 4,127
what model year?
pics of how you built the MS please.
Braineack is offline
Old 07-23-2017, 11:28 AM
vitorjorge's Avatar
what model year?
hi there
My MS is a DIYPNP 1.5 and my miata is 1.8 1996
Old 07-23-2017, 12:42 PM
Total Cats: 4,127
Originally Posted by vitorjorge
hi there
I don't I don't see the pictures
Old 07-23-2017, 12:47 PM
vitorjorge's Avatar
Old 07-23-2017, 12:50 PM
vitorjorge's Avatar
Sorry for the size...
I notice that there is missing R14 2.2K 1/4W resistor
on the board it connects to vref
Edit
ok r14 is because AC
1RMDave
Engine Performance
07-18-2019 01:19 PM
ByteVenom
07-12-2017 12:36 PM
Asx
12-15-2015 11:14 AM
mrpham
4
05-17-2012 12:38 PM
sweetmeatz
1
05-13-2009 05:03 PM
Quick Reply: DIYPNP MS2Extra - Stalling due to Sync Loss Reason 39, CAS signal
