Miata LFX Swap (Singular Motorsports & Good-Win Racing)
Old 05-01-2016, 12:41 PM
  #221
portabull's Avatar
It must be nice to have small, girlish feet.
yeah, i revisited that and it is now within 1/16" of the stock one on the left. only copied this one picture into ryan's thread though....
portabull is offline
Old 05-01-2016, 02:20 PM
  #222
ThePass's Avatar
Total Cats: 1,225
Yeah I saw in your build thread that you changed that shortly after. Mine is centered on the factory pedal's original position (Camaro pedal is slightly narrower)
Ryan Passey
ThePass is offline
Old 05-02-2016, 12:06 AM
  #223
ThePass's Avatar
Total Cats: 1,225
"Cutting corners" in the engine bay to clear the LFX
Got tired of cleaning goo out of seams so today I tackled the engine bay mod necessary to fit the LFX. V8 swaps do this same mod to the rear corners, but they also require heavy changes to the transmission tunnel/firewall. For the LFX, you only need to cut the rear corners of the bay. (yay!)
These are the offending corners, dotted line shows where they need to be squared off:
First cuts were tentative, just to see what we're dealing with behind there. The steering column passes through this area on the driver's side so that had to be removed of course:
[IMGhttp://i175.photobucket.com/albums/w157/ThePass_photos/The%20Miata/2015%20LFX%20Swap/Engine%20Bay%20Mods/DR%20side%20bay%20cut%202_zpsm482rpam.jpg[/IMG]
After more cutting. The below pics are almost there, but still more to take off the lower shelf. That shelf meets with a layer of sheet metal that comes up from below, so you don't want to take it out entirely. You want to remove as much as possible without removing that sandwich - basically cut until you see the layers separating and then weld them back together. I've added the green lines to show approximately how much is left once you've cut it back enough:
I did some searching around for what others have done to weld up this area and bring strength back to compensate for what was removed, and frankly I haven't liked anything I saw. A lot of methods, including what FM does in-house for V8 stuff is just a small bit of angled steel welded into the corner, with the rest of the exposed sheet metal edges just welded to whatever is nearby.
IMO, the full area where material was cut out should have plates welded in to transfer loads, as well as seal that area up as much as possible.
So, the plates:
Tacked into place, you can see how they tie each "loose end" where something was cut away back together:
After much welding...
Pay no mind to the un-stitched seams nearby, that's coming next.
Attached Thumbnails Miata LFX Swap (Singular Motorsports & Good-Win Racing)-dr%2520side%2520bay%2520cut%25201_zpsrmk7eons.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-px%2520side%2520bay%2520cut%25201_zpstjzmi2pg.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-px%2520side%2520bay%2520cut%25202_zpsrmrpvzgo.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-driver%2520side%2520engine%2520bay%2520cut_zps3ln95mxk.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-passenger%2520side%2520engine%2520bay%2520cut_zpsmq5el3pn.jpg
Miata LFX Swap (Singular Motorsports & Good-Win Racing)-engine%2520bay%2520plates_zpskoq0ssrw.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-dr%2520side%2520bay%2520cut%25203_zps85d4zx1w.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-px%2520side%2520bay%2520cut%25203_zps82yynrf8.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-dr%2520side%2520bay%2520cut%25204_zpseij1jls6.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-px%2520side%2520bay%2520cut%25204_zps89nguyrt.jpg
Ryan Passey
ThePass is offline
Old 05-02-2016, 06:35 AM
  #224
Boost Pope
Joe Perez's Avatar
Total Cats: 6,898
That's rather nice work.
Joe Perez is offline
Old 05-02-2016, 01:27 PM
  #225
portabull's Avatar
i'm glad this thing finally worked its way up to the front of the queue. you're gonna love it.
Old 05-02-2016, 05:13 PM
  #226
ThePass's Avatar
Total Cats: 1,225
Thank you sir.
Can't wait. There is much conflict between wanting to get it done right meow so that I can get to enjoying it and adding more to the work load by taking the time to do other things while I'm in here.
Ryan Passey
ThePass is offline
Old 05-03-2016, 04:34 PM
  #227
portabull's Avatar
the beginning of the slippery slope....
btw, don't forget to take a picture of the bottom of the pistons when you do the oil pan install. thanks!
Old 05-04-2016, 12:07 AM
  #228
ThePass's Avatar
Total Cats: 1,225
Haven't forgotten
Ryan Passey
ThePass is offline
Old 05-04-2016, 12:08 AM
  #229
ThePass's Avatar
Total Cats: 1,225
Differential temperature sensor
Tonight I turned attention back to the differential. With a seized axle in the first diff I purchased, I bought another 3.42 limited slip Getrag. This one arrived with both axles already removed (a good sign!).
Just like the transmission, I want to have solid data on what temperatures the differential is seeing under hard use so that I can determine whether or not coolers will be needed. So, my first step is to add a temperature sensor. I'm again using an Accutech SMI oil temp gauge for this as they are super accurate and affordable.
Drained the diff and then flipped it over and scoped the inside through the drain hole. Turns out there's a perfect spot for the sensor. In this first pic you can see just looking in from the drain hole at the right side of the diff that there's a partition just ahead of the drain hole but then a nice flat area on the inside wall just behind that:
Moving further in, we get a good look at that flat area and you can see there is a circle cast into the inside wall there:
Interestingly, that inner circle corresponds to one of two circles in the outside casting. Red "X" marks the spot for drilling on the rear circle. DON'T mix them up and drill into the forward circle as that will put you right into the partition on the inside:
Once again, drill a pilot then drill out with "O" size bit using grease on the bit to catch shavings. Then tap for 1/8-27 NPT threads. Do this with the diff right-side-up so that any shavings that do end up inside fall towards the drain:
Sensor installed (and after cleaning up the diff housing):
Attached Thumbnails Miata LFX Swap (Singular Motorsports & Good-Win Racing)-57d6d408-9161-41ad-b211-3b9ccf0bb9fc_zpsozkor3d9.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-f59d3f96-ad87-499b-819e-0bbbf6e501ba_zpskrwion3z.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-426fcc6c-e583-48d7-a08a-7fc038bef6d2_zpsvpx9ggot.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-6537c62c-d823-4634-b706-5ba2bdeb06a7_zpscmaxhp6u.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-77a00144-3cfe-4539-a533-d2d853d10e21_zps6cdgbslt.jpg
Ryan Passey
ThePass is offline
Old 05-04-2016, 12:13 AM
  #230
cordycord's Avatar
Total Cats: 494
Default brake ducts
And don't forget the super-cool and fabulous Singular brake ducts. You know, as long as you're down there.
Attached Thumbnails Miata LFX Swap (Singular Motorsports & Good-Win Racing)-80-img_4032_e9b00ae604601e8662894b419a59df4845814175.jpg
cordycord is offline
Old 05-04-2016, 05:39 AM
  #231
Scaxx's Avatar
Total Cats: 885
I really appreciate this post, I had no idea as to where to put the sensor. Cats.
Scaxx is offline
Old 05-06-2016, 04:05 PM
  #232
ThePass's Avatar
Total Cats: 1,225
The modded gas/clutch pedal fixture just came back. Bead blasted and powdercoated.
Attached Thumbnails Miata LFX Swap (Singular Motorsports & Good-Win Racing)-c18f869f-5163-425f-95db-5ab2e48429ff_zpsuhobqvpk.jpg
Ryan Passey
ThePass is offline
Old 05-06-2016, 05:20 PM
  #233
turbofan's Avatar
Total Cats: 1,021
I can get behind this type of powder coating. Same finish as the brake ducts?
Ed@949Racing/Supermiata
www.949racing.com
www.supermiata.com
turbofan is offline
Old 05-07-2016, 02:51 PM
  #234
ThePass's Avatar
Total Cats: 1,225
Yep, Singular's color
Ryan Passey
ThePass is offline
Old 05-07-2016, 02:57 PM
  #235
Boost Pope
Joe Perez's Avatar
Total Cats: 6,898
True story:
I never realized that part of the car was removable.
Also, the addition of a 3 minute poached egg to a hamburger (along with the usual sliced, pickled jalapenos, a dab of catchup, and some sriracha) is quite nice.
Old 05-07-2016, 05:17 PM
  #236
Every part of the car is removable
Old 05-08-2016, 01:29 AM
  #237
cordycord's Avatar
Total Cats: 494
I finally tried the egg in the avocado half last night. Bake 425 for 15 minutes, with a strip of bacon on top and some cheese. Oh, is this considered hijacking a thread?
True story:
Old 05-08-2016, 03:36 AM
  #238
ThePass's Avatar
Total Cats: 1,225
Got into the motor today, starting to get familiar with it.
Oil pan pulled to swap it for the low-profile one courtesy of V8R. Have to pull the crank pulley to pull the pan, and I had to take a grinder to one of our pulley pullers to narrow the fingers so the would fit the pulley. Also ordered a new crank pulley bolt as it is torque-to-yield, part number 11569873:
Crank trigger wheel is internal and located at the back of the engine. Beefy 6-bolt main bearing caps (4 from the bottom and 1 of each side coming through the block wall). View in this pic is from the back of the motor:
My particular engine came from a Camaro that had flipped in an accident (it wanted to be a Mustang). This meant some extra work for me because the oil cap had been broken (part number 12642516) and some dirt had made its way into the driver's side valve cover/cam area and that meant more disassembly to clean everything out. Not wanting to risk missing anything, I pulled both the valve covers and the main front cover so I could thoroughly clean everything. To pull the front engine cover you need to remove the power steering pump, and to remove that you need to first remove the pulley on that pump. While I was in there, I also found that one of the four cam position sensors was cracked, so a replacement for that is also on order (part number CSS1909). There are 3 timing chains:
Attached Thumbnails Miata LFX Swap (Singular Motorsports & Good-Win Racing)-c11a52ca-63a1-4de7-a899-377d3df4f370_zps9n3nhnqn.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-d0d54a58-cef9-46d8-bca6-3265e842663c_zpsixcnzo2j.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-d90ac658-1f3e-42ae-b6b0-580c32edb3d6_zpsxl0qbla1.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-d4cb5cb1-1a87-42c6-9f03-c55add6d8f0c_zps7zruchjj.jpg   Miata LFX Swap (Singular Motorsports & Good-Win Racing)-b8ca0dfc-b355-4da7-8291-1643d30cd1c9_zpsvcuomyqu.jpg
Miata LFX Swap (Singular Motorsports & Good-Win Racing)-05081e83-72db-4b61-bf3d-6e79fcd03625_zpsax93kadg.jpg
Ryan Passey
ThePass is offline
Old 05-08-2016, 04:00 AM
  #239
gooflophaze's Avatar
Total Cats: 156
Ugh that looks like a bear of a job. Looks like you're making good headway.
And I think my dad meant the faceting grinds on the crankshaft weights.
gooflophaze is offline
Old 05-08-2016, 04:11 AM
  #240
ThePass's Avatar
Total Cats: 1,225
Not that bad of a job as long as you've got some time and a puller/pusher that works on that P/S pulley. Silicone scraping and re-applying on that massive front engine cover is a little tedious though
Some sockets that usually lie in the toolbox untouched in a Miata shop are getting some action on this new motor... 1/2", 15mm , 18mm, 22mm
Yeah the cross-hatch on the bottom of the pistons looks pretty standard. Will take a couple pics of the counterweights tomorrow.
Ryan Passey
ThePass is offline
Quick Reply: Miata LFX Swap (Singular Motorsports & Good-Win Racing)
