MAP sensor reading ~97 kPa all the time
Old 04-16-2016, 07:37 PM
Joseph Conley's Avatar
Default MAP sensor reading ~97 kPa all the time
I have a used enhanced MS2 for 1.6 and the MAP sensor always reads ~97 kPa. Even if I attach a short hose to it and blow/suck it will never change. Is there a chance it went bad? Do I need to calibrate it? I am able to start my car and it will idle pretty rough at ~10-11 AFR on the base map for this ECU. I am guessing because the MAP reading is so far off. Is that a correct assumption?
This is where I attached the vacuum line originally on the car before I removed it and tried to blow/suck to test MAP reading.
Attached Thumbnails MAP sensor reading ~97 kPa all the time-80-img_20160415_161255_4ba5f31dd36a4efe416031c654a505efb77e1ab4.jpg
Joseph Conley is offline
Old 04-16-2016, 09:19 PM
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
If the sensor itself isnt blown, the circuit may be, but yes, its in the ECU. This isnt a calibration issue. No it will not run right with no MAP.
hi_im_sean is offline
Old 04-17-2016, 07:21 AM
Total Cats: 4,102
post the MSQ just in case, but yeah they can go bad. typically happens after a winter and when the MAP sensor is vertical. Condensation is able to drip into the MAP sensor and freeze.
Braineack is offline
Old 04-17-2016, 01:19 PM
Ok, Ill do that tonight when I get back to the car. Just to double check if I have to replace the sensor, the MPX4250 2.5 Bar sensor is most likely what Ill want to replace it with right?
Old 04-17-2016, 06:52 PM
I hope I added the attachment correctly.. This should be pretty close to the default map for this ECU. Thanks.
File Type: msq
Old 04-21-2016, 05:11 PM
Ok, I replaced the map sensor and now it reads 94.5 kpa all the time and does not change when I blow/suck on the vacuum line. What do I do now?
Old 04-21-2016, 05:42 PM
Total Cats: 4,102
is this a diypnp?
Old 04-21-2016, 06:01 PM
is this a diypnp?
A used enhanced MS2 for 1.6.
Old 04-21-2016, 10:27 PM
This is the connection after I replaced the original map sensor before I cleaned them up.
Bump with photos of board. I am really dead in the water until I can get this figured out.
Attached Thumbnails MAP sensor reading ~97 kPa all the time-80-mircrosquirttop_2b9871ebb16a931457743468fa403d9496d66fcc.jpg   MAP sensor reading ~97 kPa all the time-80-microsquirtbottom_96c06f2c826a23ab852680d5129034b91ef08a63.jpg   MAP sensor reading ~97 kPa all the time-80-daughterboard_2b27865f38df9868f8cc7e05e240bc079cf7f2b5.jpg   MAP sensor reading ~97 kPa all the time-80-postnewmap_e059962519afdbda304d94754fd17d16d663385c.jpg
Old 04-21-2016, 10:41 PM
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Check to make sure the sensor is getting its 5v and has a good ground. Im assuming you can get MS2E schematics? start there
Old 04-22-2016, 08:55 PM
Update! I checked the voltage between pin 3 and ground. Pin 3 is labeled as MAP sensor input on the MicroSquirt module. As I suck and blow on the vacuum line I see this voltage raise and lower as expected. This tells me my sensor is good and is getting power and the issue lies either in the MicroSquirt itself or somewhere in TunerStudio. My guess is its not TunerStudio.
I also checked the resistance on C11 (From what I can tell is a 0.1 cap). I switched my multimeter to 20k ohms and the screen read 8.88. Is that what its suppose to be? Sorry, I dont know the proper terms to explain it better.
Attached Thumbnails MAP sensor reading ~97 kPa all the time-80-vcheck_4e2a71e5d9ddbee6fe71709c950d58af8c2e9814.jpg
Last edited by Joseph Conley; 04-22-2016 at 10:29 PM. Reason: Corrected C1 to C11, C apparently stands for capacitor
Old 04-22-2016, 09:14 PM
Another thing to note, I am getting voltage going into C11, but I am not getting any voltage out of C11. Im assuming I should. Any idea?
Old 04-22-2016, 10:56 PM
I think I have found the correct schematics and will attempt to figure out what is wrong:
http://www.msextra.com/doc/pdf/Micro..._Guide-3.3.pdf
Old 04-22-2016, 11:15 PM
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
C designation is usually a capacitor.
Edit- if thats the correct schematic, it goes to gorund to filter noise or something. As long as it not shorted, its not an issue. Yours isnt shorted.
Do your voltage check whole blowing and sucking ( ) on R5 on the C12 side.
edit edit- and from there you can check it on pin 27 of the processor chip
im going to be you have a software or settings issue
Old 04-23-2016, 04:05 PM
Total Cats: 4,102
make sure the signal makes it to the CPU.
Attached Thumbnails MAP sensor reading ~97 kPa all the time-80-blob_8040450b486f40efe41c367922221473eca7909f.png
Old 04-23-2016, 07:03 PM
I checked all points along the trace, the resistor, and pin 27. All getting the correct voltage, well at least the voltage changes when I blow/suck on vacuum line. I even reflashed the ECU just to make sure I didnt change a setting somewhere that would cause it to act like this. Just as a sanity check, I should be able to see the engine MAP gauge change even with the car off correct? Also, the only ini error that wasnt related to vvt, was this:
Warning: [GaugeConfigurations] gauge template assigned to undefined OutputChannel: maf, Problem at:
[mainController.ini]:[Line:6881]: mafGauge = maf, "Mass Air Flow", "g/sec", 0, 650, 0, 200, 480, 550, 0, 0
But Im guessing since it refers to gauge configs it probably doesn't effect anything.
Any other suggestions I can try?
Old 04-24-2016, 07:38 PM
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
I have a hard time believing that only 1 input pin on a chip like that could go bad, its just not how it happens in my experience. But anything is possible. It still sounds software to me, but youve already done everything i would have. Triple check that you dont have weird map/baro settings. And then I guess its time to swap that chip or board.
Lets see what brain has to say.
Old 04-24-2016, 10:04 PM
Ok, just to dump everything Im doing. I started a project using the 3.3.0f ini file I was told to use. Changed only these options from their defaults:
Megasquirt / Microsquirt selection: Microsquirt Module MSPNP/DIYPNP
EXPANDED CLT TEMP: Activated
Under sensor calibration I have the MPX4250 selected. I have tried what is the recommended values for this sensor and I have also tried modifying everyone of those fields and couldn't get the gauge to ever change.
Under general settings baro correction is set to initial MAP reading, MAP averaging lag factor is 98. MAP sample method is set to use average.
Non-Linear Baro correction is all 0s across 80-120 kPa.
I am unaware of any other options related to MAP/Baro. Is there a way to specify a MT.net user so they get a notification about a thread? I pretty sure this is built by Reverant and would like him to take a look at this and see what his opinion is.
Old 04-24-2016, 10:13 PM
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Yes
@Reverant
@Braineack
Old 04-24-2016, 10:15 PM
Thank you Sean.
Quick Reply: MAP sensor reading ~97 kPa all the time
