Puting on the crown - home straight
Boost Pope
Total Cats: 6,918
I've heard this as well, and never understood it.
It's not as though the turbine is generating heat. Yes, the exhaust gas does lose considerable thermal energy as it expands across the turbine, but that's an instantaneous transition.
In a rear-mount application with a pre-turbo muffler, does the sensor need to be located in free space a foot past the end of the tailpipe?
"Turbo cars typically produce higher EGTs, so the sensor needs to be further away. What's an easy reference for our customers to measure from?"
Ideally, they publish the max EGT allowable, and you plumb EGT fittings into your exhaust system every 3" until you reach a point where the temps are acceptable to the sensor, but that's not terribly convenient for the end-user who's installing it in their gravel driveway with a hand-drill and a flux core welder.
Boost Pope
Total Cats: 6,918
Because the sensor burns out after a month.
And sells for $59."
I only rotated the compressor housing. The oil drain faced down in its original configuration.
Original turbo alignment
It is easiest to do with the turbo off. I rotated it while I did the rebuild of its internals. It is fixed with a C-snapring that is a bitch to get to without the right / big enough pliers. And it is a locking pin on the compressor house with a pin-hole on the center housing, I drilled a new hole for the new rotated pin position, but I might have gotten away with just fileing away the pin.
Hi All
1. - Finally cleaned the car after it spent most of winter collecting dust in the garage during winter.
2. - Air filter installed at last. I've been testing the car without a filter driving around hoping nothing got sucked in to the turbo. I wonder how many degrees of intake temp i can save by putting it out to the side?
3. - Electronic boost control solenoid. Wastegate on this turbo is 1 psi so the EBC is worth its weight in gold. Its mounted by the windshield wiper fluid reservoir, with probably the longest vacuum line possible. How much response time is lost from over there?
4. - Engine bay, the flash photography really brings to attention the amount of dirt present in there.
5. - Sonic the Hedgehog - Hes fast, but faster than a turbo miata?
