OG Racing: PFC race pads.
Old 08-03-2015, 10:40 AM
  #61
OGRacing's Avatar
Total Cats: 33
just got back from a hot as hell Road Atlanta event. worked more on my brake balance. Now the Deceleration rate is incredible. i'll wear out my harness at this rate.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
OGRacing is offline
Old 08-11-2015, 02:46 PM
  #62
OGRacing's Avatar
Total Cats: 33
you can watch my lap here. had a real hard time with the trans not wanting to shift, so the whole track was 4th -5th
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 08-12-2015, 07:43 AM
  #63
Total Cats: 3,133
I'm going to be super critical here: It looks like you turned in early for 9, missed the apex and then pinched the track out and lifted early for 10a. I've been in the passenger seat at 158mph in a Porsche street car going into that braking zone and I know your car has more capability than you were comfortable using. Stay on the throttle until it is time to use the brake. And use the whole track if you aren't blocking for position, lol.
Looks like a fun car.
sixshooter is offline
Old 08-12-2015, 11:55 AM
  #64
OGRacing's Avatar
Total Cats: 33
Thank you for the advice. anyone that says they know everything is a liar. I have a new splitter so getting used to turn 10a braking is a whole new world for me. i need to relearn it. i was also lifting before turn 6 because i ran out of gear in 4th and a clutch hydraulic issue wouldn't let me shift into 5th. i still think the car has a 1:35 in it as it sits.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 01-27-2016, 10:04 AM
  #65
OGRacing's Avatar
Total Cats: 33
order yourself a RSR and get a Big *** PFC KIT.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 02-17-2016, 07:52 AM
  #66
Total Cats: 3,133
Did PFC reformulate their street pads in the last 5 years? I just put some on the Tundra and they are great. One of the guys on another forum said he tried some back in '09 and they dusted badly and ate rotors on his van. After 2 weeks it seems these I bought don't dust much at all.
The guy at O'Reilly's surprised me when he offered PFC as an option since I didn't know they had them.
Old 02-17-2016, 10:15 AM
  #67
OGRacing's Avatar
Total Cats: 33
yep, they changed the street formula every few years just to keep on top. the new 19 compound is coming out shortly. should be similar to a hp+ with less dust and higher temp rating, say 1400* vs hp+ 700* max.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 02-17-2016, 01:02 PM
  #68
Total Cats: 3,133
So I can track the Tundra?
Seriously though, these pads are incredible compared to the cheapo ones that were on it previously. I highly recommend them.
Old 02-17-2016, 02:37 PM
  #69
stefanst's Avatar
Total Cats: 74
And for Pete's sake talk them into making the 11 and 19 compounds in the sports brake size!
stefanst is offline
Old 02-17-2016, 03:58 PM
  #70
OGRacing's Avatar
Total Cats: 33
i'm working with them now to make the Corvette c6 Z06 pads. After that i'll work on sport pads.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 02-22-2016, 03:18 PM
  #71
OGRacing's Avatar
Total Cats: 33
97 compounds are back in stock.
PFC 97 compound. good for dirt and small tire applications. low Tq friction levels that cater to lower traction that provide excellent modulation characteristics. good for 200QUTG tire and lower.. mild to no aero cars.
yes they will throw sparks.
0525.97.14.44
Click here for more information->***
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 03-28-2016, 10:52 AM
  #72
OGRacing's Avatar
Total Cats: 33
97 compound would be an excellent match for the new new maxxis tire that was released today.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 03-28-2016, 01:43 PM
  #73
OGRacing's Avatar
Total Cats: 33
Congratulation to Jim Drago and dominating all weekend at the SCCA majors @ Road Atlanta. 2 Pole positions and 2 race victorys. Jim races on PFC pads.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 03-28-2016, 01:44 PM
  #74
Chilicharger665's Avatar
Total Cats: 57
Do you have stuff for NCs? I just bought one and I need pads that work well enough to drive 5+ hours to the track, not kill me on track, and then drive me home.
Chilicharger665 is offline
Old 03-28-2016, 01:49 PM
  #75
OGRacing's Avatar
Total Cats: 33
for the NC i've been sending padgid yellows. the same ones Freedom autosport uses. the problem with the nc is getting the life from them. the yellows where the only ones that lasted.
what tire are you running?
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 03-28-2016, 02:01 PM
  #76
Total Cats: 57
Sumitomo HTR Z III's. 245/40/17 on a 17x8. They are what the car came with, but I plan on going with wider wheels and better tires once they wear out.
Old 03-28-2016, 02:10 PM
  #77
OGRacing's Avatar
Total Cats: 33
Search results for: 'mx-5'
here you go. use these. the MX-5 had a real hard time on Hoosires making the pads last a full 2 hours. it's a large tire, with a thin pad. these where the only pads that would cut the mustard. on the tires your using they should last you a long time.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Old 03-29-2016, 04:18 AM
  #78
Total Cats: 57
Ok, so run the yellows in front, orange in back? I assume I need to resurface my rotors for these to work?
These can also be driven around town, correct?
Old 03-29-2016, 06:00 AM
  #79
Total Cats: 57
Ok, I re-read the thread in an attempt to be more useful and I saw you saying that I can swap race pads from the current street pads when I go to an event and swap right back over to the street stuff when I get back with no ill effects?
Old 03-29-2016, 10:17 AM
  #80
OGRacing's Avatar
Total Cats: 33
With PFC's yes. padgids can be a bit more finicky, they can have some pad build up issues when you mix transfer layers. do use a fresh rotor or a cut rotor. best is to have a set of track rotors that stay with the pads.
on a mx5 if you want to keep one set of rotors, i would use a set of hawks. go for the DTc-60 Front and DTC-30's rear. They won't last as long as the padgid, and it will engage the ABS easier, but pad slapping is easier. they also don't start working at lower temps like the padgids. so street driving in cool weather should be done with caution.
Hawk HB522G.565 Racing Pad - DTC-60 Compound
Hawk HB523W.539 Racing Pad - DTC-30 Compound
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OGRacing is offline
Quick Reply: OG Racing: PFC race pads.
