OGK
#87
Saturn Vue steering column with this Saturn Vue ion Chevrolet Equinox ? Electric Power Steering Controller Box ? Epas | eBay
I'm doing this on the XP car after I get the LNF in and working.
#93
I'm another in the use the electric column option if you can legally modify the steering column inside the driver compartment. The GM columns are cheap and there's already and aftermarket controller for them. If you have to go hydro, the Volvo pump might be a better option than the toyota because the volvo doesnt require special fluid and is literally 1/5th the cost while being substantially more available.
#100
I think the ribbing is just there for pleasure......
Did you get the straight cut or helical gears? Maybe I missed that but I saw the gear ratio you picked but not the gear type.
I'm sure that the 375bhp rating is probably conservative but wish is was a little higher for what it costs. Would be nice to be able to run this on a higher HP turbo build with out having to be nervous about having 10K wrapped up in your trans.
