OGK
Old 02-15-2016, 05:59 PM
  #81
Blackbird's Avatar
Total Cats: 412
Originally Posted by ThePass
CBR1000RR > R1
Lies.
CBR1000RR = R1, both can weigh down roughly the same amount of papers as far as I'm concerned.
Blackbird is offline
Old 02-15-2016, 08:49 PM
  #82
No paddle shifters?
Old 02-15-2016, 09:06 PM
  #83
Total Cats: 2,387
Originally Posted by aidandj
No paddle shifters?
Probably not. Paddles require a separate pneumatic pump, lines and control system. The paddles available also move with the wheel, not big paddles that stay on the column like a WRC car. Paddles are cool but I'll stick with something simple to set up and use.
.31 SNR
emilio700 is offline
Old 02-15-2016, 11:41 PM
  #84
ThePass's Avatar
Total Cats: 1,216
Develop short-ratio steering rack, never cross arms on-track again, paddle shift to the win...
Ryan Passey
ThePass is offline
Old 02-16-2016, 12:15 AM
  #85
Total Cats: 2,387
I am contemplating an electric pump somewhere in the middle of the car for power steering. It's going to be tough to muscle 275s on 11s with all that aero otherwise.
Paddle shifting is just another layer of cost and complexity I am ok avoiding.
.31 SNR
Old 02-16-2016, 09:10 AM
  #86
Blackbird's Avatar
Total Cats: 412
Have a look at electric power steering columns from small Toyotas (IIRC Yaris).
Old 02-16-2016, 10:06 AM
  #87
mcfandango's Avatar
Saturn Vue steering column with this Saturn Vue ion Chevrolet Equinox ? Electric Power Steering Controller Box ? Epas | eBay
I'm doing this on the XP car after I get the LNF in and working.
mcfandango is offline
Old 02-16-2016, 01:47 PM
  #88
arbinshire's Avatar
CarbonMiata is doing carbon front and rear fenders for it.
It'll be interesting see if that actually materializes, or materializes with sufficient quality.
arbinshire is offline
Old 02-16-2016, 01:54 PM
  #89
Total Cats: 2,387
Pretty sure I'll keep the Miata rack to keep that part simple. Just add a new pump since the standard Miata pump tends to blow up when it gets hot. It'll also be nice to get the weight of the pump off the nose.
.31 SNR
Old 02-16-2016, 02:07 PM
  #90
ThePass's Avatar
Total Cats: 1,216
Interested in which E-pump you choose. I'm going powered steering as well.
Ryan Passey
ThePass is offline
Old 02-16-2016, 04:54 PM
  #91
Blackbird's Avatar
Total Cats: 412
The Toyota E power steering unit is on the column, under the dashboard.
To be used with the Miata steering rack.
Old 02-16-2016, 06:29 PM
  #92
bbundy's Avatar
Total Cats: 144
Its not so bad 275's on 11 without power steering. Even my scrawny co-driver got use to it last year. Having said that I think we will keep the power on his CSP car build and I'm having to talk him into keeping it.
bbundy is offline
Old 02-16-2016, 08:04 PM
  #93
Total Cats: 104
I did it one season and said **** that. Every tiny crack in the road along the direction of travel made the steering wheel try to remove my fingers.
I'm another in the use the electric column option if you can legally modify the steering column inside the driver compartment. The GM columns are cheap and there's already and aftermarket controller for them. If you have to go hydro, the Volvo pump might be a better option than the toyota because the volvo doesnt require special fluid and is literally 1/5th the cost while being substantially more available.
Leafy is offline
Old 02-16-2016, 08:12 PM
  #94
Blackbird's Avatar
Total Cats: 412
How much does the Volvo unit weigh?
Old 02-16-2016, 11:02 PM
  #95
Total Cats: 104
I didnt weigh it, according to how much Eric claims he added in weight with the mr2 pump its a couple pounds heavier than the MR2 pump. Maybe someday I'll weigh it, it felt around the same weight as the stock ps pump.
Leafy is offline
Old 03-22-2016, 04:13 PM
  #96
Total Cats: 2,387
Attached Thumbnails OGK-80-20160322_125233_acff1c228afa81ec083cb4f40671a2384c56b022.jpg
.31 SNR
Old 03-22-2016, 04:14 PM
  #97
Mobius's Avatar
Total Cats: 365
Hnnngg
Mobius is offline
Old 03-22-2016, 04:18 PM
  #98
Blackbird's Avatar
Total Cats: 412
Attached Thumbnails OGK-80-wtu5pso_a462f7cc0204721367f44381d68b0f8d4033f169.jpg
Old 03-22-2016, 09:59 PM
  #99
k24madness's Avatar
Total Cats: 95
Nice! Look forward to seeing some vids in action.
Interesting case ribbing. I assume that design helps counter case twist.
k24madness is offline
Old 03-23-2016, 03:51 AM
  #100
julio's Avatar
Total Cats: 23
I think the ribbing is just there for pleasure......
Did you get the straight cut or helical gears? Maybe I missed that but I saw the gear ratio you picked but not the gear type.
I'm sure that the 375bhp rating is probably conservative but wish is was a little higher for what it costs. Would be nice to be able to run this on a higher HP turbo build with out having to be nervous about having 10K wrapped up in your trans.
julio is offline
Quick Reply: OGK
