T5 trans development
Old 01-23-2012, 01:00 AM
gearhead_318's Avatar
Total Cats: 21
But since a Miata weighs less the a mustang, the T5 should but up with a lot more power, right?
gearhead_318 is offline
Old 01-23-2012, 02:01 AM
Full_Tilt_Boogie's Avatar
Total Cats: 407
Yes.
The domestic worlds views on transmission strength is very, very different than ours.
They're breaking T5s with 3000+ lb cars usually running on massive sticky tires and being as mean as possible to them.
Full_Tilt_Boogie is offline
Old 01-23-2012, 03:57 AM
Wildanimal's Avatar
Back in my mustang and Camaro days, t5's were a frequent fail part but so was a 700R4 auto. V8 torque and the weight of the car have to play a significant factor in durability.
The T5 should stand up much better considering the weight of a miata and the lower low end torque numbers of the turbo cars.
Wildanimal is offline
Old 01-23-2012, 05:06 AM
NiklasFalk's Avatar
Total Cats: 63
Originally Posted by DeerHunter
It's too bad the Quaife gears are no longer available (price probably had a lot to do with it).
The "wide range" Quaife (QKE3K, 2.564 1st and 0.794 5th) is still available and will be available for at least a couple of more years (according to the Quaife rep I talked to at Autosport last weekend). £1476.00 plus VAT isn't dirt cheap though.
With the Quaife and a 3.6 you get 1st identical to a 6speed 2nd with 4.1.
With my 4.875 I would with a Quaife set get a 1st that's taller then the 6sp with 3.6 (which I know is on the short side even with stock power from the 03 I had to 8 years). But I'm far from the torque range to have issues.
A 1st of 2.2-2.6 seems to be what's wanted.
Edit: What about this wide gear set for the T5?
http://www.gearboxman.co.uk/infot5.html
Ok, getting a new box and then start to modify it adds up. I'ts easier to convert a 6sp to a 5sp with a dogleg "1st"
NiklasFalk is offline
Monk
12-11-2016 02:21 PM
Trent
10-01-2015 12:15 PM
cheeseclock
Meet and Greet
15
09-12-2015 08:53 AM
Baxgordum
09-04-2015 11:42 PM
elesjuan
02-09-2008 02:13 PM
Quick Reply: T5 trans development
