#121
Total Cats: 2,103
![Name: vvttesting4.jpg
Size: 118.4 KB](https://www.miataturbo.net/attachments/aem-59/199480d1501240397-thread-where-savington-asks-lot-really-really-dumb-questions-vvttesting4.jpg)
I can snap one with the car running if you want it. I did check the actual duty cycle on the parameter screen, it was changing as I adjusted the duty vs. target table. I fiddled a bit with the target table to see if that had any effect, didn't seem to.
#124
OK then check that it's reading correctly first.
At some higher RPM ...
Does it read 23* retard with 0 duty cycle?
With 100% duty cycle, does it then go to 0-1* retard?
The easy way to directly output a given duty cycle is with the VVC Out max and min options. e.g. set min to 99 or 100% if you want max duty, and set max to 0 or 1 if you want 0. You may have to change both e.g. set min to 98 and max to 99, then set min to 0 and max to 1.
If it's not reading correctly, adjust "cam start".
EDIT:
Goddamit I reviewed my post #86 again.
Manual says
Cam Range = (360 Degrees/# of Fuel Teeth per rev)/0.8
That's PER REV (2 teeth), not per cycle (4 teeth).
That would give 225* for "cam range" (not 112.5) if you wanted to read crank degrees.
Because the ******* software won't accept >100*, I suggested using 56.25 and think in terms of cam degrees. Well that won't work either because it would need 112.5 to do that which is >100.
Here's an idea. Instead of reading off cam advance in cam degrees, how about 0 to 10? (yes a bit lame). Think of it as 10ths of max retard/advance. To do that the "cam range" multiplier needs to be 47.87.
You then need to adjust "cam start" so that max retard reads out close to 10, or max advance reads close to 0.
EDIT:
Manual says
#125
Total Cats: 2,103
The best things are discovered by accident. All the crap I did with the settings at idle did nothing, but as soon as I backed it out of the garage tonight to go autocrossing tomorrow, it fell flat on its face above 2500rpm. Sure enough, the cam angle is changing by 12+ degrees. I turned it off since it obviously needs to be tuned, but we're there.
#126
Total Cats: 2,103
Had a chance to play with this a bit tonight.
First thing: Higher number in the target table is more advance. I can hold the car at 2500rpm, and if I increase the target in that cell the car will eventually die (too much advance). Same with duty cycle, 100%DC is no advance. If I set it at 60, the car idles fine. Set it at 40 and the car will immediately die, just like it did when I put +12v on the solenoid at the beginning.
With the error table set up as Jason had me set it up (positive slope), the car obviously dies as soon as there is even the slightest bit of transfer in the spool valve, since the assumption was that more duty = more advance. I need to poke through the manual again, but we may be able to flip all of that around by just inverting the signal.
Numbers aren't quite important yet, but if possible I want to use a multiple of the actual advance being applied, vs a 0-10 scale, just so it's easy to discuss settings and such with Hydra guys.
#129
Total Cats: 2,103
Bringing the duty cycle down to 10 did nothing, but then at about 6% it would shut the car off from an idle. I revved it to 3000rpm and it ran rough, and then I quickly inverted the error table and it stabilized at ~7 "degrees". Cam #1 angle is reading approximately 1.81, full retard is 1.92.
#131
Total Cats: 2,103
We may want to expand on the range, larger than just 0-10 - it reduces resolution in the error table by quite a bit.
#132
Total Cats: 2,103
30%. 30.08%, to be exact. With the error table set at 0%, 30.4% will hold full retard, 30.08% holds full retard, and as soon as I go down to 29.6% it begins to slowly advance the cam. I can then go back to 30.08 and hold whatever advance I want (within a degree, about as accurate as the Cam#1ADV ever gets).
#134
Total Cats: 2,103
#135
The largest number you can put into cam range is 100. If you put in 100 the cam readout will go from 0 to 20.9. If you put in 95.74 it will read from 0 to 20. The resolution of the target map will be about 2.2* (crank degrees) which is OK.
If you install a crank trigger wheel with at least 6-1 teeth then you can make it readout 0-47*.
It looks like the output of inj#9 is inverted - check the box "vvc#1 invert" so that 0 duty displayed is actually 0 output.
