rattle can aluminum charge pipes?
Old 04-30-2007, 10:15 PM
Default rattle can aluminum charge pipes?
Curious about your experience with spray painting charge pipes. Thinking about blasting my pipes with some sort of hi temp black tomorrow. Maybe a crinkle finish if I am feeling froggy.
Old 04-30-2007, 10:41 PM
Mine have lasted....did a metal flake silver....with all the oil spills they could use a touch up, but all in all it looked better than rust/dirt/flat black
Old 04-30-2007, 10:45 PM
did you use a standard paint--or go with some hi temp stuff?
I'd like to send my pipes out to be powdercoated, but since I'm probably going to re do my intercooler and intake situation soon enough, I'll hold out.
Black pipes, and new couplers, and my engine bay will look bitchin'. Might even go with t-bolt clamps, not because I think I need them, but because they look cool.
Old 05-01-2007, 07:54 AM
i used high temp metalic red on mine it looked candy when it was done i need to redo it though. after all the mods dents chips ive added etc. i would not ceramic it though you want it to transfer heat out. not store it. just my 2 cents GL man
Old 05-01-2007, 08:06 AM
expensivehobby22's Avatar
I POR-15d mine. Flat grey for me, but they have a silver color as well.
expensivehobby22 is offline
Old 05-01-2007, 08:50 AM
I actually used the remaining wheel paint i had left over....high-temp ceramic on the valve cover.
Old 05-01-2007, 09:55 AM
I did mine in hammered finish gunmetal at one point. actually was pretty durable where it wasn't rubbing the hood.
Old 05-01-2007, 07:16 PM
I went to town on both sets of IC pipes today with some hi temp flat black. I'll get a pic later.
Old 05-01-2007, 07:35 PM
Pitlab77's Avatar
my friend did flat black krylon.
Pitlab77 is offline
Old 05-01-2007, 07:39 PM
I painted the AFM too....
and please ingore the ugly wires by the brake booster. I put the EGT probe in, but didn't have time/energy to do anything else after that
Old 05-01-2007, 08:21 PM
jwarriner's Avatar
I've had really good luck with Dupli-Color engine paint on IC pipes, I usually use satin black and I've done valve covers in red and silver. May not have a million colors but it's super forgiving, goes on nice and stays on. Also, my motorcycle tank is painted with it and it withstands gasoline if you don't let it sit forever, so oil and grease should be no problem. I also like the cast iron (that's what my tank is painted with) and cast aluminum for various other parts. It's good **** and it'll stand up to the heat of IC pipes no problem.
Here's some crap pics.
Motorcycle tank in cast iron.
Silver valve cover, black heat shield (yeah, the engine enamel stayed on the heatshield) and touched up stock IC/MAF pipes all in black.
Red VC, cast aluminum intake manifold, touched up stock IC/MAF pipes.
Attached Thumbnails rattle can aluminum charge pipes?-after_frontq2.jpg   rattle can aluminum charge pipes?-talonengine.jpg   rattle can aluminum charge pipes?-p1010012.jpg
jwarriner is offline
Old 05-01-2007, 11:07 PM
Cool, apparently I took another pic because this was on my cam too. You can see the black AFM here, as well as the wastegate can and I painted the filter housing too.
Old 05-01-2007, 11:33 PM
I used some of that crinkle spray paint from home depot on mine and its still there. Makes for a nice faux powder coat - a great way to bring up curb appeal of those aluminized charge pipes for sure.
Old 05-01-2007, 11:53 PM
turbopezz's Avatar
i used the same paint ,it really does look like powder coat.
turbopezz is offline
10-03-2015 11:04 AM
Aroundcorner
10-01-2015 03:20 PM
Trent
10-01-2015 12:15 PM
Quick Reply: rattle can aluminum charge pipes?
