99-00 ITB setup
99-00 ITB setup
This is a homemade itb setup for my 99 miata. it is incomplete and will need a little work to finish them. The head flange needs to be redrilled or replaced, the bolt pattern is backwards .... DOH. I have moved to CO and can no longer find the time or the air density to use these anymore. I am looking to just pay for the velocity stacks i had made so i will sell the kit for $270
Gsx-R 600 38mm throttle bodies
secondaries removed
spacing modifications complete
needs a tps sensor
needs flange re drilled
needs throttle bracket to be made
comes with a vacuum manifold
the copper lines are just vacuum lines
http://itbconversion.blogspot.com/
^ more info
secondaries removed
needs a tps sensor
^ more info
chris101
10-09-2015 09:08 AM
JesseTheNoob
09-30-2015 02:44 PM
