I want your spool data!
Total Cats: 4,126
If some of you remember this thread: https://www.miataturbo.net/forum/sho...ighlight=spool
we started collecting spool-up rates of various turbo setups and threw them into a chart.
I would like to collect new data and try again.
So please respond using the follow example:
Engine: '93 1/6L
Turbo: T3 Super 60 .48 A/R
Manifold: BEGi Cast "Directed Pulse"
Downpipe Size/Style: Single tube 2.5" to 2.75"
Exhaust Size: 2.75" to 3"
Exhaust Components: Louvered resonator & Magnaflow Muffler
Intercooler Core Size: 18"x12"x3"
Intake Manifold: Stock
Headwork: Mild Porting, deshrouding, blended bowl
Engine Management: Megasquirt
Other Spoolin' Helpers/Hurters: Toyota COPs
Trans & Rear End Ratio: 5-speed, 4.1 LSD
Rear tire size: 205/45-16
FOURTH GEAR PULL:
RPM Boost(psi)
2250 1.88
2300 2.46
2400 2.9
2500 3.48
2600 3.77
2700 4.5
2800 5.65
2900 6
3000 7.25
3100 8.1
3200 9.57
3300 10.7
3400 11.75
3500 12.2
3600 13.5
3700 14
Leave it on topic, or posts will get deleted. Try to take the log in 4th gear to keep things constant, and start the pull from 2K. Have fun, don't need to keep pulling to 7K and go +100mph
Engine: '93 1/6L
FOURTH GEAR PULL:
RPM Boost(psi)
2250 1.88
2300 2.46
2400 2.9
2500 3.48
2600 3.77
2700 4.5
2800 5.65
2900 6
3000 7.25
3100 8.1
3200 9.57
3300 10.7
3400 11.75
3500 12.2
3600 13.5
3700 14
DEI liberal femininity
Total Cats: 574
Engine: '01 1.8L
Turbo: GT2876R .64 A/R turbine housing
Manifold: ETD long tube mild steel
Downpipe Size/Style: 2.25 to 3" transition with external wg
Exhaust Size: 3"
Exhaust Components: cat, resonator, magnaflow big muff.
Intercooler Core Size: Begi #2
Headwork: zip
Engine Management: hydra
Other Spoolin' Helpers/Hurters: Toyota COPs, intake valve advanced 6degrees, super light flywheel/clutch.
FOURTH GEAR PULL:
RPM PSI
2300 0.0
2350 0.6
2400 0.9
2500 1.2
2550 1.6
2700 2.2
2800 2.5
2850 2.8
3050 3.4
3100 3.7
3150 4.1
3200 4.4
3250 4.7
3350 5.6
3400 5.9
3450 6.6
3500 7.2
3550 7.8
3600 8.1
3650 8.7
3700 9.0
3750 9.4
4000 9.7
4050 9.7
4100 9.7
4150 9.7
Exhaust Size: 3"
Headwork: zip
FOURTH GEAR PULL:
RPM PSI
2300 0.0
2350 0.6
2400 0.9
2500 1.2
2550 1.6
2700 2.2
2800 2.5
2850 2.8
3050 3.4
3100 3.7
3150 4.1
3200 4.4
3250 4.7
3350 5.6
3400 5.9
3450 6.6
3500 7.2
3550 7.8
3600 8.1
3650 8.7
3700 9.0
3750 9.4
4000 9.7
4050 9.7
4100 9.7
4150 9.7
Engine: '99 1.8L
Turbo: Garrett GT2560
Manifold: BEGI cast, directed pulse
Downpipe Size/Style: BEGI stainless single tube
Exhaust Size: 2.5"
Exhaust Components: All Magnaflow: metallic high flow cat, resonator, muffler (stealthy)
Intercooler Core Size: 12"x12"x4"
Intake Manifold: stock
Headwork: none
Other Spoolin' Helpers/Hurters:Megasquirt controlled EBC with GM valve, 2.5"-3" IC plumbing over-the-top
Atmosphere ~98 KPa
FOURTH GEAR PULL:
RPM Boost (psi)
1717 0.45
1801 1.19
1915 1.63
2004 2.08
2203 3.12
2426 4.75
2616 6.24
2816 7.42
3004 8.61
3198 8.17
3407 8.32
3611 8.32
3795 8.32
4018 9.06
4233 8.61
4444 9.35
4609 8.76
4805 9.35
5007 8.76
5241 9.06
5409 8.76
5598 8.76
5818 8.76
6022 8.61
6284 8.76
6310 8.76
EDIT: I logged a 4th gear pull on the way home today just for this thread. The data above has been updated accordingly.
Exhaust Size: 2.5"
Headwork: none
Atmosphere ~98 KPa
FOURTH GEAR PULL:
RPM Boost (psi)
1717 0.45
1801 1.19
1915 1.63
2004 2.08
2203 3.12
2426 4.75
2616 6.24
2816 7.42
3004 8.61
3198 8.17
3407 8.32
3611 8.32
3795 8.32
4018 9.06
4233 8.61
4444 9.35
4609 8.76
4805 9.35
5007 8.76
5241 9.06
5409 8.76
5598 8.76
5818 8.76
6022 8.61
6284 8.76
6310 8.76
Total Cats: 2,104
Engine: '94 1.8 liter, OEM 150k longblock
Turbo: GT2554R
Manifold: BEGi Cast "Directed Pulse" (standard S2/S3) with EGR
Downpipe Size/Style: BEGI 3" SSSG
Exhaust Size: 3"
Exhaust Components: BEGi DP, custom 3" midpipe with metal-core 3" cat, 3" Enthuza catback
Intercooler Core Size: 27x6.5x2.5"
Headwork: OEM
Engine Management: MSPNP
Other Spoolin' Helpers/Hurters: Toyota COPs, MS EBC
FIFTH GEAR PULL: (equivalent of a 4th gear pull in a 5-speed car)
RPM Boost(psi)
1750rpm: 1.0psi
1870rpm: 2.1psi
2014rpm: 3.3psi
2478rpm: 5.4psi
2626rpm: 6.1psi
2783rpm: 7.3psi
3004rpm: 9.4psi
3188rpm: 11.0psi
3394rpm: 12.5psi
3601rpm: 14.1psi
Specify what tranny/rear end you have as well. My 5th gear and everyone else's 4th gear is the same.
Turbo: GT2554R
Exhaust Size: 3"
Headwork: OEM
RPM Boost(psi)
1750rpm: 1.0psi
1870rpm: 2.1psi
2014rpm: 3.3psi
2478rpm: 5.4psi
2626rpm: 6.1psi
2783rpm: 7.3psi
3004rpm: 9.4psi
3188rpm: 11.0psi
3394rpm: 12.5psi
3601rpm: 14.1psi
Engine: '94 1/8L
Turbo: GT2860rs
Manifold: BEGi S4 stainless tubular
Downpipe Size/Style: BEGI divorced
Exhaust Size: 2.5"Exhaust Components: Magnaflow Muffler, metal cat
Intercooler Core Size: 18"x8"x3"
Headwork: none
3rd GEAR PULL:
RPM Boost(psi)
3300 = 1psi
3450 = 2psi
3487 = 3psi
3495= 4psi
3520 = 5psi
3550= 6psi
3620= 7psi
3640= 8psi
3660= 9psi
3700= 10psi
3780= 11psi Limit
Total elapsed time 1.36 seconds in 3rd gear. Taken from track day datalog. Was best full throttle example from a low rpm I could find. Makes boost earlier on other logs but this was the cleanest example.
Turbo: GT2860rs
Headwork: none
3rd GEAR PULL:
RPM Boost(psi)
3300 = 1psi
3450 = 2psi
3487 = 3psi
3495= 4psi
3520 = 5psi
3550= 6psi
3620= 7psi
3640= 8psi
3660= 9psi
3700= 10psi
3780= 11psi Limit
Engine: '92 1.6L
Turbo: TD04L-13T from 06 Subaru WRX
Downpipe Size/Style: 2.25"
Exhaust Size: 2.25"
Exhaust Components: 2.25" flex joint with one 2.00" crush bend radius, 18" straight-through resonator and dual-chamber muffler
Intercooler Core Size: I dunno, its a 1st gen. Ford Probe turbo with 1.75" in/out; probably 12"x8"x2"
Headwork: Stock
Other Spoolin' Helpers/Hurters: Nothing
Rear End Ratio: 4.3
Rear tire size: 205/50-15
FOURTH GEAR PULL:
RPM PSI
1500 1.1
1700 1.3
2000 2.0
2200 2.6
2500 4.8
2700 9.4
3000 10.0
3500 10.1
5000 Clutch Slip
6000 Clutch Slip
6500 Clutch Slip
7000 Clutch Slip
Exhaust Size: 2.25"
Headwork: Stock
Rear End Ratio: 4.3
FOURTH GEAR PULL:
RPM PSI
1500 1.1
1700 1.3
2000 2.0
2200 2.6
2500 4.8
2700 9.4
3000 10.0
3500 10.1
5000 Clutch Slip
6000 Clutch Slip
6500 Clutch Slip
7000 Clutch Slip
Total Cats: 404
Nice. I was the last post and was never included. ::sniffle-sniffle::
Engine: '94 1.8L
Turbo: two Garrett GT1548
Manifold: Shore Motorsports Absurdflow TT muhahaha
Downpipe Size/Style: 2x 2.25" upper's blended into single 3"
Exhaust Size: 3" Absurdflow Stainless
Exhaust Components: 3" Magnaflow cat and 5x8x18 Magnaflow muffler
Intercooler Core Size: 18"x12"x3" side entry tube/fin ebay special
Intercooler Plumbing Size: 2.5" Stainless
Intake Manifold: Custom rotated plentium for thru-fender I/C plumbing welded onto stock lower half of intake manifold
Headwork: stock '94
Engine Management: AEM EMS
Other Spoolin' Helpers/Hurters: ?
Trans & Rear End Ratio: '92 5-speed, 3.9 torsen
FOURTH GEAR PULL:
RPM Boost(psi)
2000 0.0
2200 1.0
2500 2.0
2750 3.0
2950 4.0
3050 5.0
3200 6.0
3325 7.0
3425 8.0
3525 9.0
3625 10.0
3750 11.0
3850 12.0
3950 13.0
4000 13.3
269rwhp @ that 13 psi
Engine: '94 1.8L
Headwork: stock '94
FOURTH GEAR PULL:
RPM Boost(psi)
2000 0.0
2200 1.0
2500 2.0
2750 3.0
2950 4.0
3050 5.0
3200 6.0
3325 7.0
3425 8.0
3525 9.0
3625 10.0
3750 11.0
3850 12.0
3950 13.0
4000 13.3
Engine: '93 1.6L
Turbo: Mitsu small 16g
Manifold: Bottom-mount mild steel
Downpipe Size/Style: Single tube 3"" to 2.5"
Exhaust Size: 2.25"
Exhaust Components: Magnaflow 2.25" "high flow" ceramic cat, ebay cat-back with glass-pack and resonator
Intercooler Core Size: 9"x7"x2.5"
Headwork: none
Engine Management: Megasquirt PNP
Other Spoolin' Helpers/Hurters: MS controlled EBC, Fidanza flywheel
FOURTH GEAR PULL:
RPM Boost(psi)
2200 0
2300 1
2600 2
2850 3
3000 4
3200 5
3300 6
3500 7
3600 8
3700 9
Exhaust Size: 2.25"
Headwork: none
FOURTH GEAR PULL:
RPM Boost(psi)
2200 0
2300 1
2600 2
2850 3
3000 4
3200 5
3300 6
3500 7
3600 8
3700 9
Engine: '01 1.8L
Turbo: Precision SC61
Manifold: Tubular
Downpipe Size/Style: 3"
Exhaust Size: 3"
Exhaust Components: 3" w/ catalytic converter
Intercooler Core Size: 24"x8"x3.5"
Headwork: none
Engine Management: Hydra
Other Spoolin' Helpers/Hurters: FM Base map w/no tuning
FOURTH GEAR PULL:
RPM Boost(psi)
2000 0.0
2250 0.3
2500 0.9
2750 1.2
3000 1.9
3250 2.8
3500 3.1
3750 4.4
4000 6.2
4250 7.4
4500 9.7
Manifold: Tubular
Exhaust Size: 3"
Headwork: none
FOURTH GEAR PULL:
RPM Boost(psi)
2000 0.0
2250 0.3
2500 0.9
2750 1.2
3000 1.9
3250 2.8
3500 3.1
3750 4.4
4000 6.2
4250 7.4
4500 9.7
Engine: '00
Turbo: GT2554
Manifold: AVO
Downpipe Size/Style: AVO cast ordinary
Exhaust Size: 2.5" custom
Exhaust Components: metal cat, resonator, large magnaflow muffler
Intercooler Core Size: 9x16x3" AVO
Intake Manifold: Stock VICS
Headwork: DIY mild porting, deshrouding, blended bowl
Other Spoolin' Helpers/Hurters: 8.4:1 Mazda pistons, standard bore
FOURTH GEAR PULL:
RPM Boost(psi)
1800 2.5
2000 4.7
2250 7
2500 9.2
Turbo: GT2554
Manifold: AVO
FOURTH GEAR PULL:
RPM Boost(psi)
1800 2.5
2000 4.7
2250 7
2500 9.2
Engine: '00
Turbo: GT2560
Manifold: ETD shorty, internal gate
Downpipe Size/Style: BEGI custom divorced d/p
Intercooler Core Size: ~9x16x3" TDR i/c
Other Spoolin' Helpers/Hurters: 8.4:1 Mazda pistons, standard bore; metal cat is half clogged.
FOURTH GEAR PULL:
RPM Boost(psi)
2000 2.5
2250 4.4
2500 6.1
2750 7.6
3000 10.2
Turbo: GT2560
FOURTH GEAR PULL:
RPM Boost(psi)
2000 2.5
2250 4.4
2500 6.1
2750 7.6
3000 10.2
Engine: unopened stock '90 2.0L FE-dohc
Turbo: Garrett t3/t4 stage 3 AR48, 50 trim AR60
Manifold: SS Autochrome BP top-mount mild stainless steel (modified flange to fit FE)
Exhaust Size: 3"
Exhaust Components: 300 cel metal cat, 18" louvered glass-pack and Raptor turbo-style muffler (quiet)
Intercooler Core Size: 18"x12"x3" eBay bar/plate
Intake Manifold: Top half 1.6 Miata, Bottom half Kia Sportage
Headwork: none
Engine Management: FM Miatalink 1.6
Other Spoolin' Helpers/Hurters: Incomplete closed loop tune on Link EBC. Stock Mercedes internal wastegate w/helper spring. Still haven't dyno tuned the engine management...soon.
Trans & Rear End Ratio: 5-speed, 4.1 open
Rear tire size: 205/45-15
atmos: 98kpa
FOURTH GEAR PULL:
Exhaust Size: 3"
Headwork: none
atmos: 98kpa
FOURTH GEAR PULL:
RPM Boost(psi)
- 1800 onset
- 2500 2
- 3000 4
- 3550 8
- 3750 10
- 4000 12
- 4200 15
- 4400 18.7
OK the new and improved graph is posted above. The xls file is attached to this post so if you want to change the plot or add your data, go for it.
Cueball's boost slope is nuts! Pipefathers is pretty steep too.
It is also interesting that Brain and TurboTim took two completely different approaches and ended up with practically identical spool behavior.
JasonC no offense but are you sure about your numbers? Our setups are pretty similar but yours is spooling 500 rpm sooner with a clogged cat?
Of course the other factor here is efficiency and how that translates into power. It would be interesting to see a 3-D plot with power added as a third axis.
Total Cats: 404
I'll post Paul's to the best of my knowledge. He will let me know if I'm off here. The spool data is taken from the original thread.
Engine: '99 1.8L
Turbo: Garrett GT2560R
Downpipe Size/Style: Bellmouth 3"
Exhaust Components: 3" Magnaflow metalcat and 4x12
Vibrant resonator
Intercooler Core Size: 18"x12"x3" side entry bar/plate ebay special
Intake Manifold: BEGI
Headwork: stock '99
Trans & Rear End Ratio: '94 5-speed, 3.9 torsen
Rear tire size: ?
FOURTH GEAR PULL:
RPM Boost(psi)
1750rpm 0psi
2000rpm 2.9psi
2200rpm 4.6psi
2500rpm 6.5psi
2700rpm 8.5psi
3000rpm 11.6psi
3200rpm 14.0psi
301rwhp @ 14 psi
Engine: '99 1.8L
Vibrant resonator
Headwork: stock '99
Rear tire size: ?
FOURTH GEAR PULL:
RPM Boost(psi)
1750rpm 0psi
2000rpm 2.9psi
2200rpm 4.6psi
2500rpm 6.5psi
2700rpm 8.5psi
3000rpm 11.6psi
3200rpm 14.0psi
301rwhp @ 14 psi
rear tire size at that time was 215/45/15.
That was when i was just learning how to use the EBC and my chart was as follows. The 2nd one is what I run now. I should go do a log just for the **** of it.
I'll chime in with my unsorted map:
Engine: '94 1.8L
Downpipe Size/Style: BEGI SGSS
Exhaust Size: Unknown, larger than OEM
Exhaust Components: OEM CAT
Intercooler Core Size: BEGI #2
Headwork: Sandblasted during rebuild
Engine Management: Megasquirt MSPNP9495 HiRes
Other Spoolin' Helpers/Hurters: 8.6:1CR, EBC, AFR:Pig rich
Trans & Rear End Ratio: 5-speed, 4.1 Open
Rear tire size: 195/50R15
FOURTH GEAR PULL:
RPM Boost(psi)
2105 0.4
2120 1.5
2314 3.5
2521 4.8
2745 5.9
2904 7.1
3009 7.8
3100 8.7
3226 9.9
3344 10.6
3405 10.9
3549 11.7
3667 12.8
3693 13.6
3717 14.1
3933 14.4
3992 14.8
Engine: '94 1.8L
FOURTH GEAR PULL:
RPM Boost(psi)
2105 0.4
2120 1.5
2314 3.5
2521 4.8
2745 5.9
2904 7.1
3009 7.8
3100 8.7
3226 9.9
3344 10.6
3405 10.9
3549 11.7
3667 12.8
3693 13.6
3717 14.1
3933 14.4
3992 14.8
