View Poll Results: Is this motor rebuildable? / Would you rebuild it?
Yes, rebuild it. 400 hp.
25.00%
No, find another block because this one is hosed.
75.00%
Voters: 4. You may not vote on this poll
Is this crank / motor salvagable?
Old 08-15-2007, 11:10 AM
Default Is this crank / motor salvagable?
big photo to load test philips bitch:
Old 08-15-2007, 11:28 AM
Miotta FTW!
Splitime's Avatar
It's hosed. (crank at least)
If the mains look fine... just get another crank. But that looks like some oil starvation or something similar, since it is on all the rod ends... so rest is probably hurt.
Splitime is offline
Old 08-15-2007, 11:35 AM
that's what I was thinking. this looks like you might not get anything other than a shortblock out of it. a shortblock that needs machining.
Old 08-15-2007, 11:39 AM
neogenesis2004's Avatar
is that your bottom end? If you look up the bores in the pics, the rods look pretty smashed to me.
neogenesis2004 is offline
Old 08-15-2007, 11:41 AM
Arkmage's Avatar
that's pretty nasty. I don't know how much they can machine the crank down and still stay in spec... but if that's salvageable it's going to be a ---- hair away from out of spec.
Arkmage is offline
Old 08-15-2007, 11:49 AM
is that my bottom end, heh no.
it's the motor bruce has.
Old 08-15-2007, 11:57 AM
if you were mcguyver you would take a car battery and some wire and weld the rods back together, then throw some chewing gum on the crank, and it would be good to go.
<---owns every season on dvd
Old 08-16-2007, 09:29 AM
AFM Crusader
olderguy's Avatar
Total Cats: 337
On the advice of the above members, I disassembled the rest of the short block. The only damage that is not directly replaceable(piston, connecting rod, oiler) is at the one bearing that spun and locked, doing the damage to the crank and connecting rod.
The rest of the journals and bearings are pristine, so if no one buys it, I will rebuild the bottom end.
Does anyone have a link to connecting rod bearing sizes so I can see if there is enough meat left on the one position to turn the crank? Haven't rebuilt a motor since I was a kid and did my mothers straight 8 Buick.
olderguy is offline
Old 08-16-2007, 05:12 PM
Arkmage's Avatar
Originally Posted by Flyinmiata's page
"stock, +0.25mm/0.10" and +0.50mm/0.20"
on main, rod, and thrust bearings. just noticed their inch denominators are off by a decimal place.
Arkmage is offline
Old 08-16-2007, 05:31 PM
nester's Avatar
I have a bottom end for you.
nester is offline
Old 08-16-2007, 07:41 PM
what about a cyl head and what about cheap?
Frank_and_Beans
Supercharger Discussion
13
09-12-2016 08:17 PM
Joe Perez
Current Events, News, Politics
8
09-30-2015 04:41 PM
Greasyman
General Miata Chat
09-28-2015 10:44 AM
Quick Reply: Is this crank / motor salvagable?
